Another towbar electrics question
Posted: Wed Mar 21, 2012 5:37 pm
There is a lot of very useful information on here about towbars and fitting them, but I am still a little hazy as to where you actually run the electrics / cables from the towbar socket.
Do you run them under the carpet holder at the rear, or behind the bumper, or is there a void I can use somewhere? Having run along the rear of my Bongo, how do I then access the cables behind the lighting cluster? Is there a hole somewhere, or is there a good place to drill one?
I am fine with the rest, soldering and which cables to use etc, because of all the helpful info on here.
Its only a 7 pin socket.
I am going to use it for a trailer tent, hopefully this summer and hopefully in Cornwall - looking forward to the sun
Many thanks in advance
