Page 1 of 2
HELP: new reversing sensors beeping when they shouldn't
Posted: Sun Mar 18, 2012 11:35 am
OK, once you've all had a good laugh, can anyone help me with this. My DIY fitted reversing sensors beep when in reverse even when no obstacle is behind me. On one occasion, they stopped beeping when I stepped out of the van. In the main though they just do it when they shouldn't. When I first fitted them they seemed fine but unfortunately I had trapped the n/s sensor wire when refitting my towbar (which I had had off for another reason) so that quickly became u/s and the o/s sensor started beeping when it felt like it. I bought a generic one off ebay and fitted it, but the problem persisted. Both sensors work ok, but the system beeps randomly when it shouldn't. Any thoughts on what might be causing it and what I might do (it feels like capacitance build up but I'm no leccie techie). ANyone had an issue like this before?
I've posted separately about faintly glowing interior light LEDS that shouldn't. Any possibility the issues might be linked?
Grateful for any thoughts and thanks chums.
Re: HELP: new reversing sensors beeping when they shouldn't
Posted: Sun Mar 18, 2012 11:48 am
by helen&tony
Hi Mike
Don't laugh, but I have heard some models of reversing bleeper are actually set off by tow-balls...perhaps yours is one? Could you fit them on the front, and get another make for the rear, after checking whether they are set off by the tow-hitch?
Just a thought
Posted: Sun Mar 18, 2012 11:50 am
helen&tony wrote:Hi Mike
Just a thought
Hmmm yes, I do have a towball. V annoying to have to buy and fit another kit (the 1st one cost me all of £14) and how would I know if I'm buying a good one or not. I have sensors on hte front already - they are the FDB brand and go kaboinggggg when they contact something hard
Posted: Sun Mar 18, 2012 12:00 pm
by longhaul8
If you think the tow ball might be causeing the trouble why not just take the ball hitch off for a few days only 2 bolts.
Well only 2 on mine.
Steve
Posted: Sun Mar 18, 2012 12:12 pm
by helen&tony
Hi Mike
I have that sort on the rear...park it by ear sensor , which is dang good at hitching caravans and trailers to!
Posted: Sun Mar 18, 2012 12:23 pm
by dobby
I fitted a cheap set, beeps at anything. One side is always beeping - probably the tow bar. Found myself reversing near things to see if it would work. Realised how godd the reversing mirror is and rely on that now. Just means that we pack about 5 less suitcases to see out the rear window now
Posted: Sun Mar 18, 2012 1:43 pm
by MountainGoat
You should have gone for a reversing camera like mine Mike. Got it off ebay from Hong Kong so it did not cost an arm and a leg. It is a wired system so is more reliable, Dave_ Aber fixed it up for me at last years Scottish Bash. Changes from rear mirror to camera monitor screen when you engage reverse gear. I was showing it off to Big Daddy et all at Gibralter Farm last year, they thought that it was the bees knees.
Tony
Posted: Sun Mar 18, 2012 2:36 pm
by maxmataz
[quote="MountainGoat"]You should have gone for a reversing camera like mine Mike. Got it off ebay from Hong Kong so it did not cost an arm and a leg. It is a wired system so is more reliable, Dave_ Aber fixed it up for me at last years Scottish Bash. Changes from rear mirror to camera monitor screen when you engage reverse gear. I was showing it off to Big Daddy et all at Gibralter Farm last year, they thought that it was the bees knees.
Tony
Now that looks mighty impressive - don't suppose you know the name of said Ebayer - if I could get an extra 5 suitcases in the back that would be swell
Posted: Sun Mar 18, 2012 2:57 pm
by helen&tony
Yes, they're pretty good...I use a similar device combined in a rear-view mirror as a forward cam for overtaking...operated on a footswitch Colin ( who has just sold his Bongo) got it from Hong Kong, and forwarded it!...customs over here would be too easily confused with a Hong Kong parcel
Posted: Sun Mar 18, 2012 4:58 pm
You might find Mike that there is a power/sensitivity control in the unit ? If one unit has been replaced it may be taking less drive from the output and leaving the other one over driven and causing the problem.
Posted: Sun Mar 18, 2012 4:59 pm
by MountainGoat
Mine was from a company called Boboparts.com from HongKong, email
[email protected]. Don't know if they are still around.
What I got in July 2010 was an OQ wide angle car rear view reversing camera for £20.19 and a OQ car 10.2 LCD TFT rear view mirror color monitor for £52.51 but they also had 7" ones.
Exact models apprear to have changed so today you could take your pick from this lot,
http://www.ebay.co.uk/sch/i.html?_trkpa ... 581&_pgn=2
and this lot,
http://www.ebay.co.uk/sch/i.html?_nkw=L ... m270.l1313
As I said in my post from reports wired systems appear to be more reliable than wireless systems, so I screwed the camera to the high level stop lamp and passed the wires into the bongo inside the gromet with the existing wires to prevent damage. (awkward job) Then tucked the wiring in between the wall and roof linings behind my side conversion until I was half way to the front of the bongo. Dave_Aber did the rest. I took my rear spoiler off temporally to make fitting the camera to the high level light easier, this is an easy job.
Good Luck
Tony
Posted: Sun Mar 18, 2012 6:28 pm
g8dhe wrote:You might find Mike that there is a power/sensitivity control in the unit ? If one unit has been replaced it may be taking less drive from the output and leaving the other one over driven and causing the problem.
Thanks Geoff, that's a really useful tip (as always from you) and I'll follow it up.
Thanks everyone for your thoughts. I love the reversing camera but its dearer, requires more fuss and space for installation, and I was keen on a device that didn't increase my visual scanning workload. The reversing mirror is pretty good but the problem comes when you distracted and/or can't identify the obstacle (as with the slender straight edged column that escaped my visual radar in an underground car park
Posted: Sun Mar 18, 2012 9:19 pm
by stuc
I have reverse sensors fitted on my bongo and mondeo. Make sure they are not picking up the ground. If they are picking up the towball, rotate them 90 degrees to the outside and see if that works. Worked for me on the mondeo. If there is a dot on the sensor this should go to the top. Toyota rotate them on the Rav 4 when there is a rear mounted spare wheel.
Posted: Sun Mar 18, 2012 9:27 pm
Excellent Stuc, i'll check that too. Don't recall a dot though they are angled and with a sort of raised lip on one half.
Posted: Sun Mar 18, 2012 10:01 pm
by stuc
Just to add, usually the wires would come in directly from the bottom.
