Drop links
martin & lynn
Drop links
Post by martin & lynn » Fri Mar 09, 2012 9:37 pm
I have just received a pair of drop links through the post. the ones that are on the bongo the moment have a 12mm thread (19mm nut), and the new ones i received have a 10mm thread (17mm nut). obviously the mounting hole on the strut is 12mm+ im concerned that the supplied parts are incorrect, physically every other aspect is identical, are thesed ok to fit?
anyone else had this experience?
Re: Drop links
Post by Northern Bongolow » Sat Mar 10, 2012 1:27 am
http://www.igmaynard.co.uk/bongo/forum/ ... 8f#p407357.
try this for starters. the link that missfixit70 quotes is also good reading, it may help you.
