Whoops there go my electrics!
Posted: Wed Feb 29, 2012 6:26 pm
by Nippon Tuck
I accidentally pulled the leisure battery wires from my internal fuse box while the battery was still connected.. Since then no central locking, lights etc and the glow plug lamp flashes. It starts OK. I have removed the leisure battery altogether now as this was the plan in the first place.
Hopefully only a fuse, but which one and where might I find it.
Re: Whoops there go my electrics!
Posted: Wed Feb 29, 2012 9:43 pm
If Central locking, internal Lights and the ECU flashes then its normally this fuse that is in question, of if you pulled the wires out then the connections to the fuse;
Also back up power to the radio, the AFT light, No beeps from the Sound warning system, Air. Con.
Posted: Wed Feb 29, 2012 10:16 pm
by Nippon Tuck
THANKS! That was very simple.
I checked ALL the fuses in the box and mysteriously the number 1 fuse was missing! Thats why I couldn't work it out.
I can't remember, but did I have a leisure battery wire plugged into that hole?
Anyway. much appreciated.
Posted: Wed Feb 29, 2012 11:07 pm
Yes the Top Left 10 Amp and the three 15 Amps on the Top Right are the ones normally diverted to the L/B fuse panel.
