If I bought 2 of these, that would be plenty and the right stuff to use when I get round to doing the ATF oil change in a couple of weeks wouldn't it?
http://www.countrywidefarmers.co.uk/pws ... uctID=5144
Quick ATF oil qustion
Re: Quick ATF oil qustion
This is for manual gearboxes not auto transmission, can you get a refund?
- haydn callow
He hasn't bought them yet !!
Most confusing.
It's called ATF D111 - which is what you would expect to use in a Bongo transmission. But, the blurb says "multi-purpose automotive gear lubricant for drive line components, particularly manual synchromesh transmissions, For use all year round. Can be mixed with most other oils."
If you put ATF in a manual gearbox, I doubt it would last long.
Alacrity to the forum!
- Driver+Passengers
The logo on the tub looks like an auto to me.
Jsut saying...
This is in fact Q8 (Automatic 15 )Transmission Fluid to Dexron 111 spec.Driver+Passengers wrote:
Jsut saying...
But It is a bit confusing when you read the advert.
If in doubt contact the supplier.
When I pop in next weekend, I'll check the blurb on the bottle. Actually, I might ring tomorrow to make sure they've got some.
Let's say the wording is off but pic is correct, then I'm safe to go ahead one presumes?
2 of those would be fine.
a lot of the modern manual/semi auto boxes require thiner oils than the old days.
