Relay for two players?
Observer
Post by Observer » Sun Feb 12, 2012 1:31 pm
I've seen lots of mentions of different kinds of relays so hopefully someone would know, can I install a seperate head unit in the space beneath the one I have but use some clever relay trickery to switch over the speaker outputs?
The installed one plays CD + (MP3 disk), SD card, radio (but no Long wave for the live cricket on R4) and also plays DVDs via the roof mounted screen at the back which is good.
I have a better Sony unit which although won't play movies has a rear USB port (must have my music) + Mp3 player input jack and a very very good radio - it can handle my wifes ipod and my iphone. So, if I was able to supply power to both via 'piggy back' ISO thingys would it be possible to switch the speakers at the touch of a button?
I'm far too mean to lash out for a more modern job which would do all of the above :wink:
My iPhone - My office
dave_aber
Re: Relay for two players?
Post by dave_aber » Sun Feb 12, 2012 1:40 pm
You could use a couple of These. One for the front speakers, one for the rears. Supply the coils in parallel from a separate switch, or if one of the radios has an output for a power antenna, use that.
Image...Image
Observer
Post by Observer » Mon Feb 13, 2012 10:33 am
dave_aber wrote:You could use a couple of These. One for the front speakers, one for the rears. Supply the coils in parallel from a separate switch, or if one of the radios has an output for a power antenna, use that.
Thanks Dave that gives me something to think about :idea:
Observer
Post by Observer » Mon Feb 13, 2012 5:28 pm
I thought I would be able to wire some spare male/female ISO connectors to the sockets of the relays and then plug each head unit straight in but unless I'm mistaken, the advert only refers to the coil (see the questions section) the other bits are not included/available what do you think :?:
dave_aber
Post by dave_aber » Mon Feb 13, 2012 5:42 pm
Some relays are sold for equipment cabinets, where the wiring is connected to a fixed base plate, and the relay then plugs into that base. This is to allow the relay to be swapped easily without disturbing the wiring.
Seems that these are that type of relay, and the base is unavailable.
The good news is that the relay unit is the coil and the contacts - so you can still use it. You just need to solder flyleads onto the pins sticking out the bottom which would have originally plugged into the holes in the base unit.
Image...Image
321Away
Post by 321Away » Mon Feb 13, 2012 5:54 pm
just look on fleabay for speaker switches, theres loads of stuff on there for selecting input/outputs of just about every type, done loads of build like this and you can get neat little units with a 2 or 3 position switch
Julian
Observer
Post by Observer » Mon Feb 13, 2012 6:32 pm
dave_aber wrote:Some relays are sold for equipment cabinets, where the wiring is connected to a fixed base plate, and the relay then plugs into that base. This is to allow the relay to be swapped easily without disturbing the wiring.
Thanks, is it possible to tell how many pins there are on each side I reckon ISO plugs can have up to eight :?:
Also if I was to go this way, could I switch the power/ign leads the same way :?:
Observer
Post by Observer » Mon Feb 13, 2012 6:37 pm
321Away wrote:just look on fleabay for speaker switches, theres loads of stuff on there for selecting input/outputs of just about every type, done loads of build like this and you can get neat little units with a 2 or 3 position switch
Julian
So, a solution without relays? Could these switches be used for the power/ign leads (12v) also?
