starting problems
Posted: Sun Feb 12, 2012 12:32 pm
by peanutcrusher
anyone got any idears
i have been out and tryed to start the bongo this morning its been stood for around a week. there is charge in the battery and the enging turns over it seems to go to fire up but just will not start
its a 2.5 diesel on a p plate if that helps.
i have tryed to turn the key wait for the click then turn the key off and back on again so as to make sure the glow plugs are warm.
it has been throwing out a fair bit of white smoke when i got it started of late but i guessed that was just hte time of year.
Re: starting problems
Posted: Sun Feb 12, 2012 2:18 pm
by wonkanoby
how old are the glow plugs
Posted: Sun Feb 12, 2012 2:36 pm
by francophile1947
Almost certainly glow plugs, if it runs OK after a couple of minutes.
Posted: Sun Feb 12, 2012 3:05 pm
by peanutcrusher
the plugs are only about 18 months old.
Posted: Sun Feb 12, 2012 3:19 pm
by wonkanoby
check they are getting power
but they could still be duff
Posted: Sun Feb 12, 2012 3:31 pm
by peanutcrusher
what is the best way to test they are getting power.
Posted: Sun Feb 12, 2012 3:59 pm
by wonkanoby
meter or evan a bulb to the rail connects them and an earth
Posted: Sun Feb 12, 2012 5:47 pm
by peanutcrusher
i've had a friend look at the van the glow plugs are fine it seems to be losing fuel pressure he thinks. its started now once its started the once its ok it only when its left it seems to play up.
there seems to be some diesel round the top of the engine as well.
Posted: Sun Feb 12, 2012 5:51 pm
by M 80NGO
Read page 4 buddy, http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=53672
my cold start was set to idle to high, don't press the throttle at all as the ecu will turn the glowplugs off :wink:
Posted: Sun Feb 12, 2012 5:54 pm
by M 80NGO
M 80NGO wrote:Read page 4 buddy, http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=53672
Sorry page 3 #-o
Posted: Sun Feb 12, 2012 7:39 pm
by rita
Are you using Vegi oil?
Posted: Sun Feb 12, 2012 11:03 pm
by Northern Bongolow
look for a fuel leak around the return links at the injectors, is your glowplug buss bar touching on the link pipes, and has burned/rubbed through.
