Help to identify different types of diesel starter motors
Posted: Thu Oct 27, 2011 2:19 pm
by Simon Jones
Does anyone have any details on different types of starter motors available for the diesel engine please? I seem to recall the twin-battery winter setup may have a beefier motor? These photos show 2 starters removed from similar vintage vehicles but there are a few obvious differences mechanically & in the location of the connections. Thanks in advance.
Re: Help to identify different types of diesel starter motor
Posted: Thu Oct 27, 2011 2:28 pm
by Driver+Passengers
From memory, the one on the left looks like the beefier 2.2kw (?) I had in my van when I bought it.
Notice the dimple in the solenoid/switch casing, towards the terminals at the top. That's one of the indications of it being a sealed unit and that you can't get into it to service the contacts.
There's a factsheet on the members' area (http://www.igmaynard.co.uk/bongo/member ... rmotor.pdf), which you've probably read. Information overload if you do a search on here!
I think starters some have 9 teeth and some 10, but I understand they're interchangeable. You may have to adjust the cable(s) to fit as my new starter accepted one of the cables at a different angle - not much to play with IIRC.
Posted: Thu Oct 27, 2011 2:51 pm
by Northern Bongolow
the one on the right is deffo the standard simon,if your stuck ive got one of each bongos, one with winterpack and one without,to confirm the winter pack starter, but it sounds like you have that sorted.
Posted: Thu Oct 27, 2011 3:13 pm
by Simon Jones
Thanks for the info. I'm actually asking on behalf of someone else who has a pile of parts from various Bongos & needs some help to work out which one is compatible with which model.
