ECU
Posted: Wed Oct 19, 2011 8:33 pm
by big d
Does anyone know if a p reg (1996) Bongo can be re mapped? looking for more economy from the 2.5 TD.
Many thanks
David
Re: ECU
Posted: Wed Oct 19, 2011 8:49 pm
by mikeWalsall
Dunno where you are located but there is a company here in Walsall who do re maps .. maybe contact them for 'advise' ..
If they can .. then so can others ..!!
http://mijexhaust.com/product-and-services/53.html
Re: ECU
Posted: Wed Oct 19, 2011 10:18 pm
by Driver+Passengers
The ECU controls the glow plugs, rad/scav fans and little else. In particular, the fuel pump is mechanically driven. I'm not sure exactly what control the ECU exerts over the AT.
What's your fuel consumption like? Anything from 24-30 mpg is probably quite normal.
Re: ECU
Posted: Wed Oct 19, 2011 10:50 pm
by big d
big d wrote:Does anyone know if a p reg (1996) Bongo can be re mapped? looking for more economy from the 2.5 TD.
Many thanks
David
What doesn't kill me, makes me stronger
Re: ECU
Posted: Wed Oct 19, 2011 10:52 pm
by big d
Thanks guys. i get about 22 mpg. will ask and let you know>
D
Re: ECU
Posted: Wed Oct 19, 2011 11:07 pm
big d wrote:Thanks guys. i get about 22 mpg. will ask and let you know>
D
Anything from
22-30 mpg is probably quite normal.
Have you got a conversion?
Plenty on here re: improving consumption if you search a bit. Tyre pressure is a simple one. Do you know when the last ATF change was?
Re: ECU
Posted: Thu Oct 20, 2011 3:41 am
by Northern Bongolow
was reading a trade mag on light commercial vehicles today, it was headed getting more out for less in.
it stated that 20% of a vehicles fuel costs can be saved with low drag tyres.
the article was written by a spokes person of a major tyre company though
. but it does sort of back up what ive found. i run on commercial vehicle tyres on my 4x4 manual bongo, inflated to 50 psi. and get quite good economy from these.
Re: ECU
Posted: Thu Oct 20, 2011 9:38 pm
by Rhinoman
The ECU controls all the AT shift points and the lock up. It can't be reprogrammed easily and as stated earlier doesn't control the injection anyway.
