Reversing Sensors
Reversing Sensors
My camper is fitted with Parkmate PDC200 rear sensors. One has stopped working and I cannot find a supplier of replacements, I suspect they are out of production. Does anyone know of a kit that suits the Bongo I can replace these with? I also have a towbar
- maxheadroom
Re: Reversing Sensors
Got a Bongo for the Wife, Best trade-in ever
i have a mazda kit fitted but i did have a cheap ebay set on another car and they were just as good, something like this just pick the closest colour
http://www.ebay.co.uk/itm/Reversing-Par ... 4ce9ce95d6
Thanks, I will have a look at these and see which might be best, either is a lot cheaper than I had found elsewhere!
- jimpearceuk
I fitted these last week to my bongo, even came with the hole saw!
http://www.ebay.co.uk/itm/Silver-Revers ... 963wt_1037
Start to finish took about 3 hours, and I took it slow, very simple and worthwhile job.
I took pics along the way so happy to write it up, just PM me
Jim
Jim
I installed a similar one to jimpearceuk, but with an LED display which blends in nicely on the dash (I prefer a visual warning to an audible one, though it can do both). A cinch to install. Mine is the wireless version, which has given 2 years faultless service, but they do a wired version as well if you prefer (in theory wired should be more reliable, but I couldn't be faffed with more cabling running up the length of the vehicle, and the wireless works perfectly for me). The control box was mounted behind the offside rear side panel, and I can access it for maintenance by simply unscrewing a single screw and removing the door pocket if I need to (never had to). I think this may be the vendor I used http://www.ebay.co.uk/itm/Wireless-Park ... 5635c9d071
Two tonne tin drum
If you buy a set with just the buzzer you can connect everything at the rear, no need to run any cables to the front. All you need to do is find the positive on the reverse light and join into that and attach an earth. Everthing else just plugs into the control box, all tucked neatly in behind the NSR quarter panel trim.
What I like about the display, is that you can see it reading down as you get closer 0.9, 0.8, 0.7 etc, rather than just the 3 different coarse gradings of audible warning. This is a good check that the sensors are working properly, and that there's not something odd shaped behind affecting the reading. Sometimes I see a fluctuating reading when there is something curved etc behind - I wouldn't have got this with the audible warning. Using the LED display I can reliably and confidently get to within a few inches of the vehicle behind. That's the beauty of the wireless kit, you get both the audible and visual, without the wiring (well, apart from power for the display). I was initially in two minds about getting a wireless kit after reading negative comments about the principle, but took a punt 'cos it was so cheap. Glad I did now (I suppose there are good and bad kits on the market, though). I'm just plucking up the courage to drill holes in the bumper of our new car for the same kit now.stuc wrote:If you buy a set with just the buzzer you can connect everything at the rear, no need to run any cables to the front. All you need to do is find the positive on the reverse light and join into that and attach an earth. Everthing else just plugs into the control box, all tucked neatly in behind the NSR quarter panel trim.
Two tonne tin drum
Thats what I did - nice and simple and no wireless involved. Only problem was I pinched one of the sensor cables and when putting the bumper back on, but have managed to get a replacement sensor and cable off ebay (from China) for around £7 (yet to be fitted, but the connector into the box looks standard).stuc wrote:If you buy a set with just the buzzer you can connect everything at the rear, no need to run any cables to the front. All you need to do is find the positive on the reverse light and join into that and attach an earth. Everthing else just plugs into the control box, all tucked neatly in behind the NSR quarter panel trim.
Only problem I am having is the other sensor likes to chirp a bit even when it isn't near anything, and I don't know why. But its annoying.
One thing to remember is that they are what they say they are"reversing aids"do not rely on any systems 100% or you will be forking out for bumper repairs, as i have seen on many a customers car. There is no substitute for a good pair of eyes.
- Tribal Elder
I fitted a set today, display mounted above the mirror using a U-shaped bracket and a bit of plastic to hold it to the mirror stem.
I too found that one sensor would activate for no reason occasionally. In my case I was able to move the wiring for the offending sensor a few inches further away from the harness for the tail light assembly and the problem was solved! Good idea to check for correct function of the sensor system with indicators, brake lights and tail lights on as well. These might also induce interference into the sensor wiring which the "brain" mis-interprets as an echo signal.
Very pleased with it, wouldn't like to trust it completely especially in rain, snow or high winds but definitely a useful mod. It took a lot of courage to drill the four holes in the bumper though!
Peter
Peter
Excellent tips there. I'll check them out and thanks++BigPanzer wrote:Hi,
Peter
