Reversing Lights failure.
Posted: Sun Oct 16, 2011 8:43 pm
by Eat Aunt
Hi all,
Could anyone help with working out why my reversing lights have stopped working ?
Not bulb failure or fuse.
Expecting it to be the reversing light switch but don't know where it is located.
Any help is appreciated
Re: Reversing Lights failure.
Posted: Sun Oct 16, 2011 8:52 pm
by bigdaddycain
Are you still getting "reversing beeps" when "R" is selected?
Posted: Sun Oct 16, 2011 9:14 pm
by Eat Aunt
bigdaddycain wrote:Are you still getting "reversing beeps" when "R" is selected?
hello BDC
Yes I am
Tks
Posted: Sun Oct 16, 2011 9:46 pm
In that case the switch is probably working unless the voltage is being dropped across it such that the lamps don't come on but it does trigger the warning buzzer;
There are several connectors, but if both lamps are out that seems unlikely, they also use separate earths so again not a common point either.
I would try a voltmeter to check the voltage after the switch, also make sure all your other rear lights are working as well as the reverse!
Posted: Mon Oct 17, 2011 7:43 am
by Eat Aunt
Many thanks
Thank you for the replly's ...We have recently changed a load of the hoses for the cooling system, and I wondered if we may have accidentally knocked apart a connector maybe?
Glad it's not the switch
Both reversing lamps are not working :(
All other rear lamps are ok :)
Will have another look later
Posted: Mon Oct 17, 2011 12:24 pm
by rita
Hi Eat Aunt,
Did you physically check the bulbs and the feed,it is not unusual for two bulbs to go Kaput at the same time.
:idea:
