Where did that oil come from?
Posted: Mon Sep 26, 2011 8:25 pm
by Cosmic Bus
All has been well of late, but noticed today after Bongo was moved further down the drive, that it seems a puddle of oil about a foot in diameter has come from somewhere.
I can see a drip from the bottom of the undertray so first thought the small well has filled up. Was all fine yesterday before I moved it back under the carport.
Have felt all round the oil filter with a tissue, and nothing fresh there, just a bit of grime. Gave it a very small nip up, I dare say I moved it 3mm at best.
Before I get the spanners out and drop the under tray does anyone have any clues? It's a bit difficult to see but I can't tell if the sump gasket is leaking. Seems a bit of an unusual thing to happen surely?
Have done a search and all I could reall come up with was this but I'm not sure it's the problem I have.
http://www.igmaynard.co.uk/bongo/forum/ ... t=0#p90134
Re: Where did that oil come from?
Posted: Mon Sep 26, 2011 8:45 pm
by missfixit70
Do a search on oil and leak, there'll be hundreds of threads
Never heard of a sump gasket leaking on a bongo, wouldn't panic just yet, a small amount of oil can go a long way, not that unusual tbh.
Could be diesel from leaking fuel pump seals/perished hoses (mixing with the crappy stuff on the bottom tray before dripping off) power steering fluid, gearbox oil, diff oil, engine oil.
Check all your levels to see what, if anything has dropped, get the bottom trays off, clean everything off & see what's leaking, most are relatively simple fixes.
Posted: Mon Sep 26, 2011 9:04 pm
by Cosmic Bus
I'll check the fuel seals Kirsty. I did them earlier in the year I think or end of last. I don't remember the leak causing the look of spill to be as black last time tbh, and counted them out as all was well leak wise after repair.
Def got me thinking now, as I was only thinking that after a full brim and 275k I'm somewhere between quarter and half tank, more to quarter and was expecting more. Not done re-brim yet. Possibly related, it's not like all journeys have been short, though most lately have just been short runs into town.
I'll look tomorrow on the drivers side.
Posted: Mon Sep 26, 2011 10:11 pm
by M 80NGO
I had a leaking camshaft oil seal earlier this month on my 2.5 diesel £4 for the seal £280 in labour to fit it
best thing to do is to remove the undertray and clean off the engine with clutch and brake cleaner ( not fluid ) then park it over some clean cardboard so that you can see exactly where the leak is coming from, my leak was running down the front drivers side of the engine block, keep us posted
Posted: Tue Sep 27, 2011 9:49 pm
by Cosmic Bus
Checked the fuel seals tonight, nothing from there. Can't see any fuel leaking so ruling that outfit now. Def hoping its not a cam seal ...
I tried taking some pics but time was against me, and kinda difficult to get the camera in. Above the sump line if you like all looks pretty clean, can't really see the front but the bolt heads on the sump at the rear have what looks like fresh oil on them, but not all.
I also checked the gearbox level and here comes a worry. Nothing on it bar a couple of clear drops (looks like moisture, not oil like), I went through the box and checked it in P, which is correct I think?, nadda.
I wonder if this explains my clutch slip sound and fuel consumption (not measured). Last time I checked, admittedly a year ago level was fine and nothing to indicate a sudden drop on the deck.
Hope the weather holds out on the weekend to drop that undertray. Oh, engine oil level ok btw and no significant drops afaik.
Posted: Tue Sep 27, 2011 10:00 pm
by mikeWalsall
Check the gearbox fluid level with a warm box ...
Move the lever through the full range several times ... hand brake on ... lever in park then check the fluid level with the engine running ..
On my Toyota the rear oil leaked from the gearbox / prop shaft seal... but that left a cherry red oil residue on the drive ..
Posted: Wed Sep 28, 2011 10:50 pm
by Cosmic Bus
Hopefully mystery solved. Decided to take her for a run to get some good temp in, primarily for the gearbox. Well that looks very clear but is just a shade under minimum.
Gave it a couple of hours and got the torch out. Can now see a drip forming under the oil filter. Turbo hose looks like it has had a fine spray of oil too. Not really sure why it has collected around the sump 'seam' as it were.
Never had this happen with a filter before, going to have to take it off now and see it if has any split in it, though more likely against the mating surface. Even though I wiped it clean and put a film of fresh round the gasket perhaps I've got something trapped. Sure hope so.
The filter is a Phram PH355 (think that's the right number, one for a Bongo anyway), guess I bought the Friday afternoon one.
Will also remember I'll lose almost a litre when I take the filter off and check level accordingly
Posted: Sat Oct 01, 2011 12:29 pm
by Cosmic Bus
Well I didn't notice this when I put it on, but got it replaced and I had lost the reciept
, but I reckon this had been going on for a while and sloshed out with a slight sloping drive and (maybe) violent movement from Mrs. Cosmic lol.
Hopefully that's the end to the story, I was going to say something about checking rubbers and leaks, but, well ...
Posted: Sun Nov 20, 2011 2:38 pm
by Cosmic Bus
Well this liitle issue has raised it's head again. Had a replacement filter, same make and part No.(Fram PH6355). The same thing has happened with the seal. Is this something I have done?? The seal was fine before I put the replacement on. Too tight?
Have now bought a Comline CMB11321 (which I notice is slighter less in length than the Fram) so lets see where I get to with this.
Driving me nuts it is...
Posted: Sun Nov 20, 2011 3:37 pm
by teenmal
Hi Cosmic Bus,
It would be worthwhile having the oil pressure checked,it could be a sticky by-pass valve/balance valve problem.If possible keeping the OP gauge fitted for a few days to monitor the system.
Cheers.
Posted: Sun Nov 20, 2011 6:52 pm
by francophile1947
Looks like what happens if you don't lubricate the seal before fitting the filter
Posted: Sun Nov 20, 2011 8:37 pm
by mikexgough
francophile1947 wrote:Looks like what happens if you don't lubricate the seal before fitting the filter
It can be..... I usually fill filters with fresh oil and smear the seal with the fresh oil...... not always possible due to filter location as on some Nissan's..... but Bongo isn't a problem...
Posted: Sun Nov 20, 2011 9:01 pm
by Cosmic Bus
I smeared the seal with oil, on each filter. Not sure I like the sound of this sticking valve business though....
Hopefully this new one should be ok, seal was not as wide on the Comline filter as it was on the Fram. After a run today, no filter drips so time will tell, fingers crossed etc etc ...
Posted: Sat Mar 10, 2012 9:44 pm
by Cosmic Bus
Well what do you know .... kept a rough eye on this over the last couple of weeks. Still getting a leak from underside of the filter. I haven't taken it off yet to check the seal. As I said before, I don't think I've ever had this issue before with an oil filter.
What's involved in this bypass/balance valve business that teenmal mentioned? Sounds expensive ...
