Thank you Rhod!!!
That is a good news. It does freeze items no problem. It's an 'Engel Outdoor Life Refrigerator' in blue color. I had a look but can't find any images of the same one on Google. I'm having a solar panel fitted and hoping to run the fridge for very long time. Do you have the factory kitchen yourself?
Fridge for Factory Fitted Kitchen
Moderators: g8dhe, umbongocat
Re: Fridge for Factory Fitted Kitchen
Yes I do - it was factory fitted to my Bongo. It's useful enough, but would be a lot better if the battery was under the bonnet. You lose a lot of potential storage space in the kitchen unit. I converted my unit to run off 240v, we're usually wild camping, so it doesn't help much. We generally have the fridge running while driving & turn it off while parked up. If I remember to turn it on/off that is! The fridge switch really needs to be the same place as the AFT one, so it's easily accessible from front or back! My other half is veggie, so no meat/fish to worry about. I've thought about going the solar panel route, but the roofrack for the kayaks is permanently fitted, so not really very practical to add panels as well. I'd be interested to hear how you get on.
Hey again.
That's good to hear...I'm relocating the leisure battery to under the bonnet this week! Well not relocating actually, since I'm getting rid of the battery under the kitchen and putting in new Elecsol 100AH battery under the bonnet. I've heard the leisure battery under the kitchen is quite small capacity, mine is also many many years old :S
Good work on the 240v transform. Would like that done but won't attempt myself...unfortunately doesn't seem to be anyone local who can help. Coincidentally, also having solar panels fitted this week! You may want to check out Dodgey on here, he installs a solar kit specifically for Bongos. Have heard you can get inflatable canoes/kayaks but whether they compare to the traditional is another thing
Thanks again for compressor info, definitely a perk
Try Hodges Autolec in Beovis Valley Southampton to sort out your 240v charging. They do the electrics for Budget Bongos and are familiar with the whole set up, including the factory kitchens. They have sorted a lot out for me over the years.
94-97 Mount Pleasant Road, Southampton, Hampshire SO14 0EB
023 8033 1774 () · hodgesautolec.co.uk
The 240v conversion was pretty easy. I was lucky to have the original Jap hook-up lead though, so could follow the method in the club factsheet. Having the LB in the back does have the slight advantage of improving its performance in sub-zero temps Not that we really need the fridge then
Thanks Terrier!
240v conversion is last thing on my list so well pleased to find someone local
Now my Bongo is ready, right in time for winter
It's a compressor fridge - I heard it - the "rumble" noise gives it away.digitalgypsy wrote:Thanks Velocette!![]()
Almost definitely a thermo-electric fridge then, quite sure it's a constant fan noise. Now apprehensively researching thermo-electric fridges
Indeed, Roger! Bongo is running like a champ, thanks for the good work
