Page 1 of 2
Hookup adapter - quality and price?
Posted: Fri Aug 19, 2011 12:27 pm
by MrSniff
Hello.
We are doing some Bongoing around Europe (France, German and Luxembourg) and on our first French site I found to my surprise (although on hindsight perhaps not) that it didn't have the "European standard" hookup points but what looked very much like ordinary indoor sockets. Having now checked the forum (wish I has before!) it seems that not only is this normal, but the wiring can also be somewhat random leading to reversed polarity.
After that long preamble my question is about the cost and presumably therefore quality of adapter - they seem to be available for £4 - £6 or £20ish. Any thoughts on whether its worth (safer) getting the more expensive ones or not?
Thanks!
Re: Hookup adapter - quality and price?
Posted: Fri Aug 19, 2011 1:19 pm
by Muzorewa
Sounds like you were lucky, we had this in Belgium, probably assembled by Smurfs....
Posted: Fri Aug 19, 2011 2:10 pm
by Alison01326
Not sure how the prices compare, but I have bought all my odds and ends (ends, mostly!) from this fellow on EBay
http://myworld.ebay.co.uk/jegs11/?_trksid=p4340.l2559
You know how sometimes you get a positive feeling about certain EBay sellers? I just had this feeling this fellow cares whether his customers are safe out there what with some of the shocking state of some continental hook up points. We saw one similar to the one Muz has pictures with loads of splitters on it and about 10 tents being served by four sockets when we were in Spain last year
Posted: Fri Aug 19, 2011 2:13 pm
by Muzorewa
Some of the Welsh ones aren't too hot either....
Posted: Fri Aug 19, 2011 2:20 pm
by Muzorewa
Oh yeah, this was another one in Belgium. Father Abraham must have put this one together
Posted: Mon Aug 22, 2011 7:43 am
by mikexgough
Buy 2 of the cheap ones..... wire one reversed and mark it with tape....then buy a plug in tester....
which will tell you via lights which is the adapter you need .....Some EU sites (especially France) have reverse polarity electrics.....
Posted: Sat Sep 03, 2011 9:06 am
by MrSniff
Thanks for all comments.
In the end I got the kit from Alison's e-Bay seller, seems the biz so looking forward to next randomly wired French campsite!
Posted: Wed Nov 30, 2011 2:32 pm
by Muzorewa
I thought this might give you a giggle, spotted on the Tertre Rouge campsite at this year's Le Mans 24 hours race.....
Posted: Wed Nov 30, 2011 5:19 pm
Humm interesting!
Why I'm glad to at least have my own RCD in my cable, not sure I would like to trust anything further back up the line
Posted: Wed Nov 30, 2011 6:34 pm
by briwy
Yep, French wiring is dead easy to do.
Any cable, any colour, any size. any where. Lucky if you get an earth.
Posted: Wed Nov 30, 2011 9:05 pm
by Simon Jones
Here's one I came across in Holland that you have to clamber over the ditch to get to. Watch out for reversed polarity which is very common abroad.
Posted: Tue Apr 10, 2012 3:34 pm
by Kitlewis
I'm taking my Bongo to the Netherlands next month - it's the first time I've driven in Europe, let alone camped...
I've got the standard three round pin blue/grey plug adapter that features in a lot of the pictures above - will I need an adapter to use that in the Netherlands?
Regards
CL
Posted: Tue Apr 10, 2012 3:52 pm
You may need an adaptor depending on which they use on a given site
http://www.davidklyne.co.uk/frencheuropeanelectric.htm its also wise to have a tester plug to check for reversals, and an adaptor to reverse it back again correctly!
Posted: Fri Jul 19, 2013 7:01 am
by helen&tony
ALWAYS carry a polarity tester plug...even in the UK i've seen some appalling hookup points, but the polarity is most often correct.
On the Continent, campers often re-wire the boxes to suit their own hookup cables, according to write-ups in various Camping and caravaning clubs, so they may have started off as an adequate installation, and been re-hashed time and time again. Listen to Geoff regarding having adequately protected cables....anything before your caravan / Bongo installation may be decidedly dangerous due to the less than adequate wiring
Regarding French wiring , as Briwy says...Oh, Boy...colours????...all mains wiring is brown here, and there's no earth....they just earth onto the neutral wire!, and many houses have 3-phase wiring indoors!!!!!!!!!!!!!.....our shower room had a 3-phase pump switch on the door frame for pumping water from the well!.....AND another by the kitchen sink!!!!!!!!
Posted: Thu Sep 19, 2013 6:48 pm
by Muzorewa
This, I reckon, is the ideal cable setup for Europe, it covers all eventualities....
1. 50m cable with normal blue BS4343 plug & socket
2. Blue plug & UK 3-pin socket (orange cable)
3. Euro (Schuko-type) plug & blue socket (white cable)
4. Blue plug & socket with live & neutral reversed (marked with earth tape)
5. Splitter
6. 3-pin polarity tester
So, if you're presented with Euro-type sockets, plug the white cable in and then add the orange one, plug in the polarity tester and see if you're ok. Check all the sockets on the hookup post while you're at it in case they're not all the same and someone kindly switches your cable to a different socket. If all's well on the tester, unplug the orange cable and connect your van up with your normal cable.
If the tester indicates reversed polarity, add the reversed cable (item 4 above) between the white & orange cables, and re-test - should be ok now, in which case leave the reversed cable connected, remove the orange one and add your normal cable.
Some would suggest just having two of the white cables, one with reversed wiring, but that won't help you if you are on a site with proper blue sockets on the hookup post and it's wired wrong.
Oh yeah, if you're using the reversed cable and need to use a splitter too - connect the splitter between the reversed cable and your normal 50m cable, then everyone else on your splitter has got the right polarity
