Rev counter dancing all over the place
Posted: Thu Jul 28, 2011 8:10 pm
by flyfisher
Over last few weeks my bongo (2.4 diesel) rev counter has been going nut’s one minute its fine and then starts dancing all over the place and then will settle back down
Any one know what the cause is and any advice, is it something that should concern me ?
I ran this past Ian who had not heard of the fault before!
Thanks (new forum member but long term club member)
Re: Rev counter dancing all over the place
Posted: Thu Jul 28, 2011 8:16 pm
by missfixit70
Welcome to the forum :D
I assume you mean 2.5l turbo diesel, there is no 2.4 :wink: Sounds like it could be the the sensor, thread here that should help - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=24171
Posted: Thu Jul 28, 2011 8:28 pm
by flyfisher
Yes that was quick and yes mean 2.5
Posted: Thu Jul 28, 2011 10:55 pm
by Northern Bongolow
could be worth checking the speedo correction chip,and that the alternator is doing what it should be too.
Posted: Fri Jul 29, 2011 1:25 pm
by karena
defo check the alternator mine was doing that when my alternator went.also have you plugged amything new into the cigarette socket once put a cheap phone charger in and had similar effects.
Posted: Fri Jul 29, 2011 3:05 pm
by flyfisher
Thanks Guys
I have a cheapo phone charger will check if it only happens when plugged in like to look at simple options first :D
Posted: Fri Jul 29, 2011 3:10 pm
by missfixit70
The alternator output should be somewhere between 13.8v - 14.6v, if it's less than that, it may be your issue, may be accompanied by sediment & charge light glowing, may not though :wink:
