RX8 wheels RX8'S RX8's **DON'T DELETE**
Posted: Mon Jul 25, 2011 6:51 pm
by mickf
Hi I'm looking to get a decent set of wheels for my 2wd 1995 auto freetop, i've heard rx8 wheels will fit straight on and what tyres i.e. load bearing no. do they have to be?
Re: RX8 wheels
Posted: Mon Jul 25, 2011 6:52 pm
by westonwarrior
92 front 96 rear
Re: RX8 wheels
Posted: Mon Jul 25, 2011 7:01 pm
by missfixit70
westonwarrior wrote:92 front 96 rear
That's absolute minimum, the 92 on the front is for a specfic size tyre of a 15 " rim, go for as high a rating as you can get, at least 98 IMO, with a speed rating of S as minimum (this includes H, which isfor heavy duty - doesn't follow alphabetically like the rest of the scale) there's a factsheet in the members area with the relevant info.
Re: RX8 wheels
Posted: Mon Jul 25, 2011 9:20 pm
by bongodonkey
I had the same q's a few months ago.
After researching I got the answers from the fine peeps on this forum.
RX8 alloys are a straight fit - which is fantastic
Load rating must be a min of 98.
Tyres - I've had a set of ACCELERAs on mine, 225/50/R18 - I went for a slightly larger profile to try and ease the bumps - however the preference is for 225/45/R18 which is what was recommended. Both are rated 99xl's
The 50 profiles, rub a wee bit when I have the full lock on whilst turning on any slightly uneven surface. The wheels are fine with no wear from this (on the plastic 'casing' inside the arches) or any damage to the plastic - it just sounds horrible!
Internet prices tend to be cheaper - http://www.blackcircles.com were the cheapest and the service was excellent £342 for the tyres and fitting!
Tyres should be kept at max pressure (mine are at 44). Also improves fuel consumption - well as best it can get on a 1.9 tonne auto V6!!
Edit: Also see this link: http://igmaynard.co.uk/bongo/forum/view ... 79#p512079
Please take your time with the new rubber on. Your braking will differ and the rolling resistance is altered which is what affects the way your bongo will stop. No biggie, just need to get used to it.
Fuel consumption - minimal difference in my opinion - motorways no change/round town a touch more thirsty!
Road noise - I don't know what you were running on prior to the RX8's, but again we didn't really notice much change - though it did make the drive a tad smoother - then again it could be my fevered imagination.
Get them on and drive really slowly through town checking your sweet ride in the shop windows........drool dribble etc!
Hope this helps - if you are about we are at the Allithwaite meet from this Friday if you fancy a peek!
Cheers now
Oz
Re: RX8 wheels
Posted: Tue Jul 26, 2011 8:05 pm
by mikeyc1
I'm in the market for rx8 wheels, which wheel bolts should be used ? anyone got any ebay links? and does a new spigot ring have to be fitted? cheers
Re: RX8 wheels
Posted: Tue Jul 26, 2011 11:56 pm
by cheffy34
I had/have 2 225/45/18s and i think you will find the best load index you will get is 92 xtra load i may be wrong ofcourse, MY V6 IS RWD ONLY :!: :!: so i opted for 245/45/18 on rear with 1oo load index looks and drives fine 245s fill the arches better on my van but now my puppy needs 4 new tyres :roll: :? i will take 245/45/18s all round trhis time easier to get the load index, fills arches better and most of all usually cheaper [-o<
Dar
Re: RX8 wheels
Posted: Wed Jul 27, 2011 12:05 am
by mister munkey
Call this lot
http://www.wheelquick.co.uk/
They keep a stock of 100 index tyres for RX8 wheels at very sensible prices.
8)
Re: RX8 wheels
Posted: Wed Jul 27, 2011 12:15 am
by cheffy34
don't fancy bringing four down too me mr M :!: do ya, do ya, do ya, do ya :!: How reasonable :wink: Give me a pm dude :wink: I've lost my supply of part worns :evil:
Dar
Re: RX8 wheels
Posted: Wed Jul 27, 2011 12:29 am
by mister munkey
I do still have two stuffed behind the shed but will have to check out roadworthyness.
Y'never know . . .
:wink:
Re: RX8 wheels
Posted: Wed Jul 27, 2011 3:16 pm
by cheffy34
mister munkey wrote:I do still have two stuffed behind the shed but will have to check out roadworthyness.
Y'never know . . .
:wink:
[-o< [-o<
Re: RX8 wheels
Posted: Thu Jul 28, 2011 6:26 pm
by mister munkey
I've got three out there Dar, 225/45 ZR 18s, they've probably got another 5000 miles left in them but one looks a little thin on the last outer inch of tread, perfectly legal though. . . .
If you can get them down your way, you can have them for the price of a pint.
I can feel a relay coming on!
Re: RX8 wheels
Posted: Sat Aug 06, 2011 9:10 am
by cheffy34
Dam missed this one Mr M, Do you know anyone coming from yours to Exeter :?: more to the point are they still on offer
Dar
