New Bongo with Leisure Battery Fitted
tonnee
Post by tonnee » Sun Jul 17, 2011 7:33 pm
Got my Bongo this week and it has a leisure battery fitted under the bonnet, I am wondering what this actually powers in the vehicle and how I can check?
Prevoius owner didnt even know it had a leisure battery whan I asked what it powered ?
Tony
1995 Bongo Auto Free Top 4WD
http://www.justgiving.com/tony-sahara
Re: New Bongo with Leisure Battery Fitted
Post by g8dhe » Sun Jul 17, 2011 7:40 pm
Welcom to the forum!
Two batteries do not necessarily mean L/B as some Bongo's come with two S/B batteries, Northern Japan cold start setup!
If you have a switch down by the drivers knee with an engine symbol on it then that indicates you have the cold start setup.
If it is a L/B then switch everything on and then just disconnect the L/B and see what stops working!
tonnee
Post by tonnee » Sun Jul 17, 2011 8:50 pm
Def a lesuire battery, thought about the other way, disconecting the standard battery and seeing what still works ?
Post by g8dhe » Mon Jul 18, 2011 8:59 pm
Either way works!
