Central Locking.
eckerB
Central Locking.
Post by eckerB » Fri Jun 03, 2011 1:11 pm
The central locking has suddenly stopped working,will it be the fob or a fuse blown??????
Where do I start to check for the fault.Thanks in advance. #-o
321Away
Re: Central Locking.
Post by 321Away » Fri Jun 03, 2011 1:53 pm
does it work if you pull/push the knob? if not then its usually the wiring between the door/body
Julian
alant54
Post by alant54 » Fri Jun 03, 2011 1:53 pm
Hi Ecker....most likely problem is wiring between drivers door and door pillar....I am sure that our more technical members will be queuing up with advice..... :lol:
You have come to the right place... :D
Alan
Sod off Julian.....you type faster than me.... :lol: :lol:
Alan...still plodding on....!
Post by missfixit70 » Fri Jun 03, 2011 5:56 pm
Could be the battery in the fob, or could be the battery supplying the CL is low.
jaylee
Post by jaylee » Fri Jun 03, 2011 8:30 pm
You didn't mention if the CL system was part of an alarm...!
Before you start pulling too much apart...!?
321Away wrote:does it work if you pull/push the knob? if not then its usually the wiring between the door/body
Julian
All the way round with the key...
missfixit70 wrote:Could be the battery in the fob, or could be the battery supplying the CL is low.
Check that one! :wink:
Then.. Power supply to the remote receiver itself.. Could be one of those pesky glass fuses in the holder come lose/not making contact in the clips..? (I only prefer blades!)
Could the aerial on the receiver be bared off at the end & touching part of the bodywork/chassis? That will/could affect reception..?
Wires running from the receiver to the locking actuator.. (Normally two wires with bullet connectors.) With door slamming they can come uncoupled...?!!
I'm assuming it's an after market system??...
eckerB
Post by eckerB » Fri Jun 03, 2011 9:23 pm
Tried the door knob to see if the CL worked and it didn`t.Tried the fob and it worked twice then nothing!I will start by getting the fob checked and go from there,thanks for the help guys.Regards Eric.
P.S. Don`t think it`s an aftermarket thing,also it`s not attached or anything to an alarm.
eckerB
Post by eckerB » Sun Jun 05, 2011 11:55 am
The C-Locking has been working again for the last 24hrs!All I have done is to hook-up our caravan,unhitched the c-van,c-locking still working?????
Post by g8dhe » Sun Jun 05, 2011 1:37 pm
Almost certainly a break in the wiring by the drivers door, its just intermittent connections by the sound of it. The trouble is the insulation may not even be broken and you may have to feel for break in each wire along it length where its stressed by the bending and clip/tie.
eckerB
Post by eckerB » Sun Jun 05, 2011 8:47 pm
Thanks again Geoff,next time the CL stops working I`ll get on it.Do you have an idea of the colour of the wire which is likely to be the culprit please or is it going to be hit and miss when looking for the break?Thanks in advance for everyones help.Eric.
Post by g8dhe » Sun Jun 05, 2011 9:28 pm
Well there are three wires which handle the CL are Blue/Red (+12v), White/Black and Yellow/Red, but I would check each wire in the loom as you will be annoyed to find that the windows stop in a week or two's time! Run each wire between thumbnail and and first finger if you fill a "notch" then be suspicious the chances are some of the wires will have broken inside the insulation even if the insulation hasn't broken.
eckerB
Post by eckerB » Sun Jun 05, 2011 10:49 pm
Thanks again Geoff,will get at it asap.
