Rear wheel won't turn in reverse
Posted: Fri Apr 15, 2011 8:56 pm
by andynew74
Has anyone got any ideas??
I took my Bongo for an MOT and they informed me the N/S rear wheel brake was binding, so i checked it out and removed the brakes including the disc, so the hand brake shoes were exposed. The wheel turns forward fine but only turns by force in reverse.. There is no diff noise and in forward its fine but you can tell there is resistance when reversing..
I had replaced a wheel stud a few weeks ago so at first suspected it was a mistake when i put the hand brake shoes back together, but as previously explaned after removing thye brakes the problem is still there???
Has anyone any ideas?? All i can think is the diff is the problem? Has anyone had the same problem?
Re: Rear wheel won't turn in reverse
Posted: Fri Apr 15, 2011 9:05 pm
by You've Been Bongod
put your location in your profile to help people near to you to help you
Posted: Sat Apr 16, 2011 12:13 am
by HeskinBongo
Is there any end float in the hub unit ? so that in reverse the float causes an issue within the diff ?
Posted: Sat Apr 16, 2011 3:30 am
by Northern Bongolow
pm sent
Posted: Sat Apr 16, 2011 9:39 am
by andynew74
Not sure about the end float. I'm going to whip the disc off again and have a good look.
Can the end float be adjusted??
Posted: Sat Apr 16, 2011 9:58 am
by rita
Hi andynew74,
Does your vehicle have a LSD.....Limited Slip Differential?.
Cheers.
Posted: Sat Apr 16, 2011 10:00 am
by andynew74
I think so.
Posted: Sat Apr 16, 2011 12:46 pm
by steviebongo
Just a stab in the dark but how's the handbrake shoes , the lineing could have fell off ?
Posted: Sat Apr 16, 2011 12:58 pm
by andynew74
I've just had a look. There appears to be no issue with brakes inc. handbrake shoes. I disconected the propshaft to eliminate anything else. It seems just one wheel won't go back without a lot of force. I am guessing its definatly the diff?? Not sure if LSD or not can't see ant tags on it. Does anyone know any good axle people??
Posted: Sat Apr 16, 2011 1:34 pm
by andynew74
I have checked on that russian site and i do have a LSD, and its 4WD.
Posted: Sun Apr 17, 2011 1:30 pm
by M 80NGO
have you tried it with either both rears or all four wheels off the ground ? Is the auto box in nuteral ?
Posted: Sun Apr 17, 2011 2:40 pm
by teenmal
M 80NGO wrote:have you tried it with either both rears or all four wheels off the ground ? Is the auto box in nuteral ?
Quote....I disconected the propshaft to eliminate anything else
Posted: Thu Apr 21, 2011 9:42 pm
by M 80NGO
teenmal wrote:M 80NGO wrote:have you tried it with either both rears or all four wheels off the ground ? Is the auto box in nuteral ?
Sorry buddy it was along day that day
