Excellent news. Things to do (incomplete, and random):
*Lift the engine covers and bonnet and get to kno what's under there, look at condition of cooling system hoses (are they swollen, do they feel hard when squeezed, no rude replies from the smutty peep please I'm being serious)l.
*Do alternator belts look good etc.
*Any sign of oil leaks (don't freak out as Bongo engines can be a bit oily but...),
*has the cooling system bleed hose been tied away so it can't chafe againt the alternator
*what is condition of battery under the bonnet
*how is the oil level and condition/colour etc.,
*do you know where the autotransmission fluid dipstick is
*is the header tank level good and are there any signs of staining.
*When driven, does the temp gauge come off the COLD stop at around 5 mins.
*What are the tyre ratings (observe and report back - they will have a number something like 96H for example stamped on the ouside wall).
*Is there a spare tyre and do you know how to remove and check it and is it pumped up properly.
*When was the cambelt last changed and do you know the service history generally.
*Has the vehicle been waxoyled thoroughly for rust protection (and you might crawl around underneath it and do a visual check).
*Have oil, air, fuel filters been changed recently.
*Does the Bongo have any steering wobble at 65-70mph, suggesting wheels need balancing (Bongos are sensitive about this)
* Do you know where the fuse boxes are and have you got a few spares
* If its an AFT lift-roof, do you know what could prevent the roof from going up in terms of handrbrake on etc.
* Are electric window switches operating smoothly and reliably and have you sussed that the drivers side switch includes a passenger window lock-out switch.
* Is the exhaust in good condition (check for rust, especially back-box)
* Be aware how easy it is to crunch into something when reversing due to limted (lower) rear vision. Think once, think twice etc. Many of us (me
) have crunched our rear ends in the early days of ownership.
And fit a low coolant alarm if it doesn't have one.
That should do for now! And have fun with it
