Petrol 2 litre cylinder head gasket
clive and val
Post by clive and val » Fri Mar 18, 2011 9:47 am
My 2 litre Bongo has a blown cylinder head gasket. I am told that this engine is difficult to repair for reasons I don't understand and its suggested that a better bet is a replacement second-hand engine. Does anyone have experience of replacing the gasket on this engine? :( Clive
lpgimports
Re: Petrol 2 litre cylinder head gasket
Post by lpgimports » Fri Mar 18, 2011 10:13 am
I've never had to do one in a Bongo 2.0 but parts are available if it purely a head gasket that is gone I can't understand their reasoning.
Paul
clive and val
Post by clive and val » Sun Mar 20, 2011 12:55 pm
Thanks for the comment Paul, it gives me some confidence in going for a repair.
Clive
steviebongo
Post by steviebongo » Sun Mar 20, 2011 1:43 pm
You need to find out why a unit change is warranted ,rather than a head gskt and possibly a skim if any distortion is evident? Which would be more cost effective than changing the unit(engine).and is it a garage with bongo experience ,do they work on these vans regulary? There are a few questions to be asked/answered before money changes hand me thinks.hope this helps .
Cheers Stevie
clive and val
Post by clive and val » Fri Mar 25, 2011 10:29 am
Hi Stevie thanks for your post. The garage has experience of Bongos but not head gasket on 2 litre. The story from the dealer who has many Bongos and uses the garage in question was that it would be better to change engine but now suggests that a repair is more cost effective. It is very difficult to get consistent advice from them. I have done engine repairs years ago before engine management systems etc so wonder just how difficult Bongo repair can be.
Clive
M 80NGO
Post by M 80NGO » Fri Mar 25, 2011 3:21 pm
Hi Mo's motors of Fenstanton did the head gasket on my 2.5 diesel, might be worth giving them a ring, i'd say that once both seats have been removed and the centre brace, access should be plentiful.
P.s if you need a head skim st ives engine services are the kiddies :wink:
Post by Doone » Fri Mar 25, 2011 10:47 pm
The access to the engine on the 2l is the same as the 2.5d, and the head/head gasket is no more difficult to replace. There's a factsheet on changing the 2.5 head gasket, which would give you an idea about the access and should reassure you.
lpgimports
Post by lpgimports » Sun Mar 27, 2011 8:40 pm
Would agree, 20 mins with a air or electric gun should see the seats out and centre panel off and then there is more space than under the bonnet of your average euro saloon. 2 litre has a inlet manifold/plenum that curls arround over top of engine which is a little bit of a pain but other than that once it is off, there is nothing more complicated doing a head gasket on any other 4 cylinder, just follow good recommended practices.
Paul
