Page 1 of 4
				New Reversing Bulb
				Posted: Wed Feb 23, 2011 10:52 pm
				by SPARKYSSS
				Not a major pimp but just put one of these in
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:IT
You can now see my Bongo reversing from space!!!!
				Re: New Reversing Bulb
				Posted: Wed Feb 23, 2011 11:00 pm
				by You've Been Bongod
				bloody hell i bet that is bright
				Posted: Wed Feb 23, 2011 11:06 pm
				by SPARKYSSS
				Posted: Thu Feb 24, 2011 6:16 am
				by helen&tony
Thanks for the pointer...Just what's needed
				Posted: Thu Feb 24, 2011 8:54 am
				by T9sus4
				Me, too!
Oh no, listing has ended!
Does anyone know which type of bulb we need for the reversing light? There are a few similar listings, but with different numbers:
http://shop.ebay.co.uk/i.html?_nkw=SMD+ ... m270.l1313
				Posted: Thu Feb 24, 2011 9:07 am
				by Triple/R
				I've copied & pasted it~hope it works~
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:IT  scroll down a bit then you'll (hopefully) see it.
				Posted: Thu Feb 24, 2011 10:02 am
				by SPARKYSSS
				Yeah the listing has ended as I bought it
There are plenty there just scroll down and add to basket.
Glad to be of service
Marc
				Posted: Thu Feb 24, 2011 2:51 pm
				by bigdaddycain
				Posted: Thu Feb 24, 2011 5:08 pm
				by SPARKYSSS
				I have run some LEDs along the underside also for the reversing but they are not quite in the centre - so weekend will be taking them off and putting on again.
Also running a strip of red LEDs alongside the white strip for a brake light
I will then be running some blue LEDs around the inside of the sliding door - any idea how to wire this up please - want it to come on when door opens (same as courtesy light)
				Posted: Thu Feb 24, 2011 5:12 pm
				by SPARKYSSS
So whats the cunning plan then Ste?????
Are all the bulbs in the rear cluster the same size??
				Posted: Fri Feb 25, 2011 8:41 pm
				by jaylee
				SPARKYSSS wrote:I have run some LEDs along the underside also for the reversing but they are not quite in the centre - so weekend will be taking them off and putting on again.
Lower the strip light & tap from that loom.
Tap into the earth switch for the strip light from the negative side of the LED's & take the constant live from the same point..
Run the wires fer the LED down behind the head lining & trim.
I may invest in those bulbs myself!
				Posted: Fri Feb 25, 2011 9:14 pm
				by T9sus4
				Sorry, I am being particularly thick here: I can't figure out which of the many LED bulbs would fit for my reversing light.
Any explanation or direct link very much appreciated!
				Posted: Fri Feb 25, 2011 11:31 pm
				by SPARKYSSS
				The bulb in the listing is a direct replacement
				Posted: Fri Feb 25, 2011 11:41 pm
				by T9sus4
				I think I need a stiff drink. The bulb that's no longer lavailable is a direct replacement.
				Posted: Sat Feb 26, 2011 9:27 am
				by helen&tony
T9sus4
I ordered from here, after reading the thread:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 158wt_1139
That'll confuse the hell out of Customs here...something from outside their normal sphere of activity...how much will they attempt to charge in duty, I wonder!!!...probably about 30.00 quid...in which case
 they know what to do!
PS...I'll let you know if they are O.K.
