leisure battery
crispy23
leisure battery
Post by crispy23 » Tue Feb 15, 2011 3:12 pm
hi,i have a problem with my leisure battery,Dory(my bongo)had a problem with the alternator which was fixed but then the air conditioning.......something was sticking and there was a smell of burning rubber! the AA was called and while in garage the air conditioning was disconnected>since then the leisure battery hasnt worked.I am in North Wales at th mo as was on holiday but mum was rushed into hospital and i need to be nearby.n e ideas wot it could be and how i check connections etc.i've only had Dory a short while so am still finding my way :oops: Oh i bought her from JAL in worcester :)
Re: leisure battery
Post by g8dhe » Tue Feb 15, 2011 3:49 pm
If you had a problem with the L/B previously had it been allowed to fully discharge ? If so a fairly common problem is that when the alternator was fixed the charging current would have been a lot higher than normal and frequently a charging fuse will blow. Check the connections from the S/B across to the L/B, you should find an in-line fuse close to each battery which are connected via a small box, the charging relay. Check each fuse will normally be about 20 or 30 Amps, its quite likely that one has blown, personally I would change BOTH fuses if one has blown as it would have been a race as to which fuse would blow first and the other one although intact may well be suspect as it would have only been milliseconds from blowing as well!
Oh nearly forget if a fuse has blown then charge the L/B from a mains charger BEFORE replacing the fuses, as the same will happen again otherwise !
