Inside rear light help
V.Mackey
Post by V.Mackey » Mon Feb 14, 2011 6:09 pm
Hi all just got my first Bongo only thing that dosnt work is the inside rear light it works when you put it to on but not when you put it to door and open the door! Any info on what could be wrong would be great!
wonkanoby
Re: Inside rear light help
Post by wonkanoby » Mon Feb 14, 2011 6:20 pm
from memory the little on of switch is down by the lock might be a loose wire
Post by g8dhe » Mon Feb 14, 2011 6:29 pm
Sounds like the door switch, if its the rear Hatch then the switch is down with the locking mechanism at floor level. If you mean the sliding door then its down on the rear pillar
Sliding door part 66-820 http://www.lushprojects.com/bongopartsm ... mgno=.html
kawasaki kid
Post by kawasaki kid » Mon Feb 14, 2011 6:30 pm
If you are on about the sliding door light check the door switch which is located at the rear wheel end of the opening just below the mid guide rail - it could just need the contact cleaning inside - if it is the rear door the switch is in the tailgate catch and may just need a quick squirt of some cleaner on the catch. Hope this helps. :)
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
bongo frenzee
Post by bongo frenzee » Mon Feb 14, 2011 6:36 pm
I had the same problem and it was a corroded fuse, might be worth checking.
Living for the weekends...
CUIDADO! VEICULO BONGO!
V.Mackey
Post by V.Mackey » Mon Feb 14, 2011 7:24 pm
Its both doors so will try it all!
