Turbo problem
MooreCock
Turbo problem
Post by MooreCock » Wed Jan 05, 2011 6:35 pm
Hi All
Think I've potentially got a problem with my turbo - put my foot down, plenty of revs, but not getting the extra 'go' that I'm used to.
Can anyone point me in the right direction to have a quick look to see if pipes have come loose etc.
Many thanks
Steve
Re: Turbo problem
Post by bigdaddycain » Wed Jan 05, 2011 7:22 pm
Hi Steve, could you be a little more specific as to when the power seems to tail off please? Is it all the time? It sounds on the surface as if the outlet pipe from the turbo has come adrift/split...
MooreCock
Re: Turbo problem
Post by MooreCock » Wed Jan 05, 2011 7:32 pm
Accelerating gently works fine, its when I try to kick-down that I don't get anything extra. Revs go up but I don't get the power surge. Noticed it today, when I went to overtake a lorry - only tried it once!
I've a feeling you're right about a pipe, just not sure where to look.
Re: Turbo problem
Post by bigdaddycain » Wed Jan 05, 2011 7:38 pm
Noramlly i'd nip out and have a look at the most likely candidate on my own bongo, but it's been at the bodyshop for weeks so i can't check for a prime suspect i'm afraid. I'm sure somebody will be along soon with perhaps a photo of the most likely "popped off pipe" The pipes may seem intact but have picked up a split or something, the boost pipe being the most likely candidate (biggest pipe).
Re: Turbo problem
Post by Doone » Wed Jan 05, 2011 7:59 pm
Have a look at the photo ON THIS LINK, it might help.
MooreCock
Re: Turbo problem
Post by MooreCock » Wed Jan 05, 2011 9:05 pm
Thanks for the help - I'll have a look when the light is a bit better.
Steve
MooreCock
Re: Turbo problem
Post by MooreCock » Tue Jan 11, 2011 9:48 am
Better light revealed nothing, so a trip to the garage it was...
"Checked and cleaned all turbo pipes, tightened all hose clips. Replaced fuel filter, and injector cleaner added".
£73.45 and it is now working again! :P
dandywarhol
Re: Turbo problem
Post by dandywarhol » Tue Jan 11, 2011 11:36 pm
Did they clean out the banjo filter at the pump too?
