Diesel fuel filter
Posted: Tue Jan 04, 2011 4:14 pm
by Oldboybob
Hi, can anyone tell me if when replacing the fuel filter on a diesel bongo (1995) do you fill up the new filter with fresh diesel before fitting. Thanks.
Re: Diesel fuel filter
Posted: Tue Jan 04, 2011 4:32 pm
by Oldboybob
P.S. I have looked at the instructions on the members area but it doesn't say there
Posted: Tue Jan 04, 2011 4:35 pm
by 321Away
You dont have to but you'll find your car will stall after 30 secs and take a bit of cranking,usually standard procedure to fill the new filter with injector cleaner so it gives them a pure dose of cleaner, if not then just put some clean diesel in.
Julian
Posted: Tue Jan 04, 2011 4:52 pm
by daveblueozzie
321Away wrote:You dont have to but you'll find your car will stall after 30 secs and take a bit of cranking,usually standard procedure to fill the new filter with injector cleaner so it gives them a pure dose of cleaner, if not then just put some clean diesel in.
Julian
I agree
Posted: Tue Jan 04, 2011 4:55 pm
by Oldboybob
Thanks fella's any particular brand of injector cleaner recommended or will any stuff do the trick?
Posted: Tue Jan 04, 2011 5:00 pm
by daveblueozzie
Oldboybob wrote:Thanks fella's any particular brand of injector cleaner recommended or will any stuff do the trick?
Redex, Wynns, STP. doesn't really matter they all do about the same job, just make sure you buy for diesel not petrol
Posted: Tue Jan 04, 2011 5:11 pm
by Oldboybob
Cheers Dave will do that tomorrow
