Coolant level
Bert
Coolant level
Post by Bert » Sat Nov 13, 2010 12:47 pm
Would you expect this to drop very gradually over time (or does this suggest a minor leak)?
Ron Miel
Re: Coolant level
Post by Ron Miel » Sat Nov 13, 2010 1:07 pm
Suggests a minor leak, unless there's been a recent full or partial coolant refill (drained off to well below the header tank bottom level), in which case a small amount of spontaneous air bleeding may still be going on. Check for leaks, watch it like a hawk and don't let the header tank drain down far, whatever you do - that way leads to air locks, overheating, hot spots and, in extremis, a cracked cylinder head. Read up low coolant alarms - use the search facility on this forum (at "board index" level).
nfn
Re: Coolant level
Post by nfn » Sat Nov 13, 2010 3:04 pm
How gradual do you mean? Surely few cooling systems as big and complicated as a bongo's will be absolutely 100% tight? My bongo has used perhaps a very dainty teacup of coolant per 6 months for the last 4 years.
mister munkey
Re: Coolant level
Post by mister munkey » Sat Nov 13, 2010 3:21 pm
Bert wrote:Would you expect this to drop very gradually over time (or does this suggest a minor leak)?
Try the cheap option first. Have a good rummage around the pipework, looking for any aftermarket Jubilee Clips that have been fitted. Chances are there will be a few, any that have been there for some time will need a quarter turn to nip them up.
That cured my 3 year long niggle.
8)
roundspoon
Re: Coolant level
Post by roundspoon » Sat Nov 13, 2010 6:11 pm
nfn wrote:How gradual do you mean? Surely few cooling systems as big and complicated as a bongo's will be absolutely 100% tight? My bongo has used perhaps a very dainty teacup of coolant per 6 months for the last 4 years.
ive had mine nearly 3 years now and 25000 miles later have still not had to top mine up yet :D
but still check it evert few days or before a long run
New Forest Terrier
Re: Coolant level
Post by New Forest Terrier » Sun Nov 14, 2010 2:52 pm
Same here - Touch Wood of course [-o< . I have had mine nearly 3years and 21k miles and apart from a tablespoon when the low coolant alarm was fitted I have never needed to top up.
This is a 95 Bongo, now past its 15th birthday, so good going for an oldie =D> .
Bert
Re: Coolant level
Post by Bert » Sun Nov 14, 2010 4:07 pm
Ron Miel wrote: Read up low coolant alarms - use the search facility on this forum (at "board index" level).
I've got one - that's how I knew the level had dropped.........
Re: Coolant level
Post by haydn callow » Sun Nov 14, 2010 4:13 pm
They do work !!
corblimey
Re: Coolant level
Post by corblimey » Mon Nov 15, 2010 9:52 pm
Just found this after posting a similar issue.
You may find this interesting
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=45192
