Radio cut out
Posted: Sun Aug 22, 2010 8:56 pm
Hi guys any one have any solutions as too why my brake light comes on during driving and turning corners, which in turn makes the radio cut until the light has gone back out?
Yes sorry northern bongolow i do me the brake warning lightNorthern Bongolow wrote:hi geoff, can you explain that a little more please.
i understand the sensor,i misunderstood which brake light he meant,thought he meant external,not the warning light on the dash.but how does that affect the radio please.
There is a signal from the breaking system to the radio, its not only in the Bongo but several other cars, I assume its to switch the volume down when breaking in order to hear external signs, its NOT part of the standard ISO10487 connector;Northern Bongolow wrote:hi geoff, can you explain that a little more please.
Thanks for the reply but the bongo has gone into melt down now ie; side door not locking on closing, hand brake light permently on now, cig lighter not working, and alarm for the ignition keys stopped working aswell. Could this be coinsidence or was it me fitting the new stereo. Whatever the reason budget bongos can have it back to sort out, we have only had it 2 daysg8dhe wrote:There is a signal from the breaking system to the radio, its not only in the Bongo but several other cars, I assume its to switch the volume down when breaking in order to hear external signs, its NOT part of the standard ISO10487 connector;Northern Bongolow wrote:hi geoff, can you explain that a little more please.
In the diagram below in the top left corner the Mazda radio connector 3I links back to the Breaking system via the (77) link click it and .....
and you will see this page (or one similar there are two variations depending on model), the (77) then links into the Breaking system;
That sounds rather like a fuse infact this one;pdo123 wrote: Thanks for the reply but the bongo has gone into melt down now ie; side door not locking on closing, hand brake light permently on now, cig lighter not working, and alarm for the ignition keys stopped working aswell. Could this be coinsidence or was it me fitting the new stereo. Whatever the reason budget bongos can have it back to sort out, we have only had it 2 days![]()
It's all in a factsheet here http://www.igmaynard.co.uk/bongo/member ... usebox.pdfpdo123 wrote:Ah cool thats a help, The fuse board you have there, do you have any reference as to what fuse is what, ie; in english. Also the large pink fuse in the bottom left corner, i dont have that one in my board, whats that for?
