LCA saves the day
Posted: Fri Aug 20, 2010 9:59 am
just like to say, what an essential piece of kit the low coolant alarm is.
i got in the bongo the other day after work and the LCA went off, so quickly had a look and the header tank was virtually empty. i topped it up to get home and had a good look around but could find no leak, so a phone call to a friendly bongo owner with a pressure test kit was made.
after 5 mins or so of pressure testing the system, the leak was visible and the water pump is goosed.
i check the levels on a regular basis and i reckon if i did'nt have an LCA fitted i would of cranked her up and gone on my way totally oblivious that the header tank was nearly empty.
cheers kev...
cheers kev...
