Help, Help - running on
Posted: Thu Jul 29, 2010 3:55 pm
by ChrisI
2.5 Oil burner wont stop running when key removed, keeps running for 2>3 mins before stuttering to a stop
Any guidence much appreciated
Chris
Re: Help, Help - running on
Posted: Thu Jul 29, 2010 4:00 pm
by missfixit70
Sounds like the stop solenoid on the fuel pump, drawing no 24-3002 on here - http://www.lushprojects.com/bongopartsm ... mgno=.html
This has come up a few times before, easy enough to test, just take it off & it should open with 12v across it & shut when it's disconnected.
Posted: Thu Jul 29, 2010 4:10 pm
by missfixit70
This thread should help source a new one too - http://www.igmaynard.co.uk/bongo/forum/ ... id&start=0
Posted: Thu Jul 29, 2010 4:12 pm
by ChrisI
Bloody flip ! that was quick..
Cheers . digging out the spanners this evening #-o
Posted: Thu Jul 29, 2010 5:37 pm
by Tomo 53
Are you sure you dont have a run on timer and pressed the button without noticing, check below the driving wheel for a small unit with tiny switches on it.the standard setting is 3 mins.
