Page 1 of 2
				HAD MY BONGO 1 DAY AND I NEED HELP
				Posted: Wed Jul 21, 2010 9:06 am
				by springer
				Hello
Nice to meet many fellow Bongo owners
I have a few problems and need advice.
1. Where can I get an owners manual ?
2. Why is my BONGO so gutless, it clearly isnt well, but struggles to start and crawls along like a snail
3. I thought the sliding door was electric, is there a hidden switch I cannot find
PS I has just been in for a new cylinder head, timing belt, & service literally a day ago, and today it just about made it back to the garage.
Cheers.
				Re: HAD MY BONGO 1 DAY AND I NEED HELP
				Posted: Wed Jul 21, 2010 9:15 am
				by ste
				sounds like the timings out... take it back to the garage.
not sure bout handbook but im sure somone on here will tell you.
the slide door is electric for the final shut,it has to go onto the catch manually and then the motor 'pulls' it too.. not sure this feature is on all bongos tho??(you should hear the motor working even if you shut it fully tho)
				Posted: Wed Jul 21, 2010 9:18 am
				by jaybeeonline
The Bongo Shop (using link at the top of the page)
If it is the 2 litre petrol, then it is a bit like that: Hang on, just seen that you had a new head and belt done, so it sounds like timing.
Not all Bongos have this feature (mine doesn't) - Usually only when you have factory remote locking I think.
J.
				Posted: Wed Jul 21, 2010 9:21 am
				by Matt&JoyBongling
				First of all welcome.
Second, your door requires manual closing ... the electric bit is the final closing mechanism which pulls it shut to avoid having to slam it.  Not all Bongos / Fredas have it but most do and it is factory fitted but not related to remote locking.
I think that owners' manuals are available throught the club shop.
				Posted: Wed Jul 21, 2010 10:39 am
				by wormey
				Matt&JoyBongling wrote:First of all welcome.
I agree with the above, mines got it ( the door final closing thing ) but I don't have remote central locking.
I'd go back to the garage about the lack of power.
daz
				Posted: Wed Jul 21, 2010 10:50 am
				by IggleDiggle
				If the garage has just done all that work and its failing to start properly, I'd get it back in there asap and get them to sort it. Least you'd expect is it to be driving properly and starting properly. Theres nothing worse than driving a car that you dont trust, and worrying when you stop at every traffic light.
Good luck and hope you get it sorted, they are good to drive when working properly.
				Posted: Wed Jul 21, 2010 10:59 am
				by springer
				Thanks for replies
Re the door, it does lock the last inch itself electrically, i just wrongly thought it opened and closed electrically.
It made it to the garage at 2mph this morning, luckily it is only 200 yards away
I still cannot find a manual in stock anywhere, guess its just a question of waiting and searching.
OH and does that bloody buzzer always go off, mine seems to stay buzzing when the roof is up, this cant be right can it ?
Cheers.
				Posted: Wed Jul 21, 2010 1:32 pm
				by Triple/R
				springer wrote:Thanks for replies
Cheers.
The buzzing should stop when roof is all the way up~i had same problem with mine it was'nt locking off~it probably has'nt been used for a long period so will need lubricating on the runners,but clean runners first,there might be some old hard grease or summat stopping the roof going all the way up~~use something like "white Lithium Grease" it wont stain your roof liner.
				Posted: Wed Jul 21, 2010 2:09 pm
				by thedogsbollox
Cheers.
Lift the roof with the engine running. I use a small child to push the roof up that last bit to lock it out. It will stop buzzing when it is right up. You will need to use the "lock cancel" button to lower it again.
				Posted: Wed Jul 21, 2010 2:30 pm
				by springer
				Roof tips taken on board, a good clean and grease and a small child needed
This one is sad.
First time in an automatic
What is the second button on the selector lever for, the one half way up the selector stick ?
Also i get P and D and R, but the others ???
				Posted: Wed Jul 21, 2010 2:32 pm
				by missfixit70
				Posted: Wed Jul 21, 2010 5:07 pm
				by danboy99
				AVA leisure have manuals in stock, or at least they did 2 weeks ago when I bought one...
				Posted: Wed Jul 21, 2010 5:29 pm
				by Velocette
				springer wrote:Roof tips taken on board, a good clean and grease and a small child needed
This one is sad.
Also if you are parked on a slope the roof might struggle to top out, mine did anyway and it's fine on the flat.
				Posted: Wed Jul 21, 2010 7:08 pm
				by thedogsbollox
				Velocette wrote:springer wrote:Roof tips taken on board, a good clean and grease and a small child needed
This one is sad.
How did you manage to get the Bongo on top of your flat?
				Posted: Thu Jul 22, 2010 8:08 am
				by springer
				Picked the BONGO up last night after day 1 in the garage and its running sweet
Had a play with the roof, and its all sorted now cheers.
After a good inspection, I have many little jobs to do, so this place will be a life saver.
