Afternoon All,
Quick question, the main indicator in the cockpit, Once pressed in,
should it flash in harmony with the side indicator lights in the dashboard ???
mine doe'nt, if it should can you advise how to remove the switch and replace
the bulb
Thanks in adcance
Jim.
Hazard Warning
jimmy1
Re: Hazard Warning
if you mean the hazard warning light switch this does not flash when you push it,but does light up when the side lights are on.
jimmy1
Re: Hazard Warning
Hi Ady
Yep thats the one,Just mine does not come on when i have my
side lights on either>
guess the bulb has gone,Can you let me know how to change it
i dont want to bust it trying to prize it apart with a screw driver
Jimmy
Jimmy
Re: Hazard Warning
i would remove the air vents either side and compress the clips that hold it into the facia mount.but these are a bit fiddly and can break,just go real careful.
i havnt taken one out so dont know if the retainer clips are on the top/bottom,or the sides.
Re: Hazard Warning
Hi jimmy,this might help you...http://www.lushprojects.com/bongopartsm ... o=.html#12jimmy1 wrote:Hi Ady
Jimmy
Ps,the hazards are indicated on the instrument cluster by Two Flashing Arrows.
jimmy1
Re: Hazard Warning
Many thanks
Jim
Jim
