Seat runner removal
wise-child
Seat runner removal
Post by wise-child » Wed Jul 07, 2010 8:23 pm
I have searched through the various topics here but cannot find the answer I need. The answers I got got tell me what to do, but not precisely how.
I want to remove my middle seats completely. I have undone and removed the four bolts and taken the seat unit out no problem. So far, so good.
That leaves two black runners. I need to remove these. I have removed the grey end bits held in with two screws and slid back the runner covers to gain access. I can see the stop bolts each side running crossways to the runner. Herein lies my problem. I know they need to come out - just cant fathom out how. Do they just hammer out?
It's a wise-child that knows it's own parents.....
Re: Seat runner removal
Post by missfixit70 » Wed Jul 07, 2010 8:25 pm
lever the circlip/washer off the end & knock the bar out, simple :D
wise-child
Post by wise-child » Wed Jul 07, 2010 8:26 pm
Thanks - I'll give it a go....
wise-child
Post by wise-child » Wed Jul 07, 2010 9:30 pm
Failed...
Do bear in mind that I have no mechanical knowledge whatsoever but I do know what a circlip/washer is - so that's probably a good start.
What can I see/work out. The thing I'm calling the runner stop is round and projects either side of the runner rails and stops the black runner mechanism from being released from the end of the rails. On the outer side it is like a flat head screw without the slot. On the inner side there is what looks like a washer joined to a nut - I presume this is what needs to be removed. Am I ok so far? I tried turning this 'nut' it moved but it rotated the whole stop bar and hence I failed to find a way to remove it.
Am I turning the right thing, is there a special tool/technique? Note - this vehicle is a newer model and in excellent condition, so there is no evidence of rust or damage to this area that might be hampering my efforts.
I'm not ready to admit defeat... quite yet.
Post by haydn callow » Wed Jul 07, 2010 9:39 pm
Just lever it off...it's a sort of spring clip....you will probably destroy it..
Post by missfixit70 » Wed Jul 07, 2010 9:44 pm
Or just hit that end with a hammer, should force the headed pin through.
Post by Bob » Wed Jul 07, 2010 9:45 pm
I'm sure Madmile has done a Fact Sheet on turning the middle seat, details must be on that, however info so far is good. :D
wise-child
Post by wise-child » Wed Jul 07, 2010 9:46 pm
Aaaahh - destroy - now there's something I'm reputedly good at! :oops: :lol: Sadly the sun has even hidden its face now so I shall attack the problem again after work 2moz. [-o< [-o<
I'm determined to get my side kitchen unit fitted in, with minimal assistance, no matter what! A fellow Bongo Fury member has kindly offered to wire in the electrics properly for me so I don't have to worry about that bit - but I can't expect them to do this supposedly simple prep as well... [-X
Learning curve? - it's the ascent of a Harrier jump-jet!
wise-child
Post by wise-child » Wed Jul 07, 2010 9:47 pm
Hammer? My favourite tool... :lol:
dave_aber
Post by dave_aber » Thu Jul 08, 2010 2:56 am
Ahhhhh, the good old air cooled percussion adjuster.......
Image...Image
wise-child
Post by wise-child » Thu Jul 08, 2010 9:31 am
dave_aber wrote:Ahhhhh, the good old air cooled percussion adjuster.......
Yep, that wonderful multi-purpose tool. I find it brilliant as a decompressor as well - I get steamed up, I thump something and the pressure abates.... :lol: :lol:
Amazing piece of technology.
wise-child
Post by wise-child » Sat Jul 10, 2010 1:05 am
Good news is that I not only got that wretched pin out in the end, but my kitchen is now fully in situ, yay! =D> =D> I even relocated my spare table the other side of the van.
All in all, I'm feeling pretty chuffed with the change! :D :D :D
Post by missfixit70 » Sat Jul 10, 2010 1:19 am
Bob wrote:I'm sure Madmile has done a Fact Sheet on turning the middle seat, details must be on that, however info so far is good. :D
Wasn't Madmile but the factsheet on reversing the seats does indeed show how to remove the offending pin :wink: With photos 8)
Glad you got it sorted WC :D
