Possible issue with willington kit
Posted: Mon Jun 21, 2010 8:44 pm
by droodle
I've had a willington leisure kit installed for a couple of months and was just checking the engine which was off and noticed the green LED was on. I can't check the install doc at the moment but if i remember rightly the relay LED should come on after i start the engine providing a circuit to the leisure battery, as it stands with the relay closed at the moment when parked up i'll be draining both batteries which means theres a fault - prob the relay .. is that correct ?
thanks.
Re: Possible issue with willington kit
Posted: Mon Jun 21, 2010 8:47 pm
by Alison01326
I had a problem with mine the other week (the relay had packed up) and I contacted Martin via EBay and found him to be very helpful indeed (I sent it back to be fixed and with his efficiency and that of the Royal Mail, it was back almost by return). I suggest you contact him too.
Posted: Mon Jun 21, 2010 9:04 pm
by droodle
ok i suppose that means me unwiring everything as i paid someone to fit it .. spose i'll have to pay someone again
Posted: Mon Jun 21, 2010 9:06 pm
by dobby
There was a bit of a chat at the bash about this, maybe he's had some bad luck with a bad batch of relays?
Posted: Mon Jun 21, 2010 9:40 pm
by westonwarrior
droodle wrote:ok i suppose that means me unwiring everything as i paid someone to fit it .. spose i'll have to pay someone again
Contact Martin before you do anything, he may give you enough guidence to take the relay out with out disturbing the rest, yourself.
Posted: Mon Jun 21, 2010 9:45 pm
by droodle
i've sent him a message before i do anything .. cheers all.
Posted: Mon Jun 21, 2010 9:55 pm
by dave_aber
Ditto here. Relay stopped cutting in. Contacted Martin, and he assisted with diagnosis. Once it was confirmed dead he sent an advance replacement, and paid for my postage when I sent the duff one back. This is six months after I bought it. My only concern is that there do seem to be a lot of these failures, as mentioned above it may be a bad batch issue. Martin is certainly giving out excellent customer service and is investigating what is going wrong with these relays. He certainly has an excellent product and reputation to defend.
Edit : Due to the decent design of this kit, the replacement of a relay takes about 10-20 mins depending on how fat your fingers are. Mine are fat and I did it in about 10.
Posted: Mon Jun 21, 2010 10:13 pm
by dandemann8
Must agree, I had an issue a couple of month's ago but Martin sorted the problem out with a FIRST CLASS SERVICE.
Posted: Mon Jun 21, 2010 10:17 pm
by Alison01326
I had an auto electrician fit mine, and got him to take just the relay off and do whatever was necessary to keep everything on the straight and narrow (don't know what he did, but it only took 5 minutes). Got said auto electrician to put the relay back again and test everything. I think in total the whole two visits only took about 15 minutes. Being an honest chap, he only charged me for 15 minutes. Worth a try?
As a matter of interest to those of you who are wondering about a bad batch of relays, I'd had mine about a year.
Posted: Mon Jun 21, 2010 11:19 pm
by hembramacho
Bakey had a problem with his fridge at the bash - draining the battery, which Madmile sorted.
At first look under the bonnet it looked like the green light was on on the willinton, which was a bit wrong, but then we (or Ed) realised it wasn't on, but just the bright sun shining on it, making it look like it was on.
Just a thought.
Andrew
Posted: Mon Jun 21, 2010 11:33 pm
by droodle
Um no it was pitch black and the LED is definitely on, thanks tho.
I've been in touch with martin and he is helping me out ..
this leads me onto my next Q which i shall start a new thread for ..
Posted: Tue Jun 22, 2010 5:03 pm
by waycar8
I have an early one, (without the green led), and havent had a problem with it since getting it about 2 and half years ago, its been on both my bongos and worked purrrfectley
(ive opened my mouth now
Posted: Tue Jun 22, 2010 6:47 pm
by Wicker Man
Where's this green LED then? Can't see one anywhere. Mine's about 18 months old - maybe its one of the old types?
Posted: Tue Jun 22, 2010 7:06 pm
by dave_aber
Top of the relay unit itself.
