Central locking and starter motor?
Posted: Mon Jun 14, 2010 10:17 am
Having a nightmare. Sorry if it's a repeat.
I have central locking on my Bongo which makes you press the key fob button after you've put the key in the ignition.
About once a fortnight, it just won't start. I canhear the click in what i presume is the starter motor but it won't do anything else. After five minutes random swearing, fob pushing and key turning, it starts as though nothing is wrong.
Recently the central locking has only been working on the driver's door. You have to go around and manually lock all the other doors. Again, this is random. Sometimes it works fine. It's a pain in the backside with four kids in tow.
I've tried my usual garage and they can't find anything wrong (because of course, it works fine when I book it in). I tried calling a few electrical specialists in the Northampton area but they hadn't even heard of a Bongo and were frankly rude and dismissive.
Can anyone help? is it simply a case of my starter motor needing a clean? Is this something a blind amateur could do or do I need a Bongo-Friendly expert?
Your thoughts are appreciated.
Motha.
Motha.
