Fog light switch
Dean
Fog light switch
Post by Dean » Wed Jun 09, 2010 9:35 pm
My Bongo came with a crappy aftermaket fog light switch. I've just bought a proper one but have no idea what the 4 terminals are used in what order.
Has anyone got any idea?
Dean
jaylee
Re: Fog light switch
Post by jaylee » Wed Jun 09, 2010 10:06 pm
Dean wrote:My Bongo came with a crappy aftermaket fog light switch. I've just bought a proper one but have no idea what the 4 terminals are used in what order.
Dean
There are a couple of different types...
Like one o these..?
Or the one in the middle here?
Dean
Post by Dean » Wed Jun 09, 2010 10:25 pm
it's like the centre one in the bottom photo
jaylee
Post by jaylee » Wed Jun 09, 2010 10:31 pm
Dean wrote:it's like the centre one in the bottom photo
OK..? Did yours come with a block connector & a few inches of loom?
lpgimports
Post by lpgimports » Thu Jun 10, 2010 12:53 am
Shouldnt be that hard to work out with a meter that does resistance. I used to grab any out of old mazda's in scrap yards UK Mx5's the 323 etc had one that was similar..
Paul
Post by Northern Bongolow » Thu Jun 10, 2010 2:40 am
as far as im aware any rear fog light switch must either have a light in it to say its on or a light on the dash to show its on,just something else to think about.but i stand to be corrected.
jaylee
Post by jaylee » Thu Jun 10, 2010 9:03 am
Dean, the one that matches yours has a green ON light at the top. (Bottom pic.)
Mine in constantly pressed to on because i used it to break continuity to the earth from the spotlight relay when off, which is triggered by main beam.. (So it lights when the main beam light comes on on the dash.)
Now, its been a while since i set this up, so wire memory ain't so good.
I also rigged a red bright led in the lower back light portion to come on & show if i left my lower factory fog lights on when dark... (I'm more likely to get flashed by dazzled oncoming at night.)
My rear fog i rigged an on light in a spare lens in the dial pod.
If yer really stuck i can pull it out & run my meter over it, & try to find out what does what in a "normal" set up for the fog...?
Dean
Post by Dean » Thu Jun 10, 2010 6:32 pm
Thanks for the help, I'll have a fiddle and see how it goes
Alifriendee
Post by Alifriendee » Sat Sep 04, 2010 10:09 pm
I have one too.
Did you find out which wire to attach to which connection?
