Bost hose baz
Posted: Tue May 18, 2010 1:14 pm
Found the offending hose is this 15-185 from coolant schematics ?
seems accesible enough for even me to have a go. Any tips?
Bit strapped after underseal job can i get this hose from shop to fit now ? Do rest when funds allow.Checked out thread. Thanks mate .missfixit70 wrote:Looks like that's the current major offender, see this thread - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=39683 I'd think about getting them all done asap as that's the second one that's gone
Well thanks again will have a look. What about that underseal job? Stinks a bit mind.missfixit70 wrote:Probably have to order it from your local Mazda dealer, part number is in the thread somewhere, or on lushprojects (just make sure you get the one that looks the same as there are 2 other options for the 2 petrol models too), have a good check of the rest & see if any are imminent, especially top hose under drivers seat & the one at the rear that goes over the starter.
After I had mine underseal I had to drive home 50 miles, the underseal smelt great for the first 6 or 7 mile, by the time I got home I hated itbongobaz wrote:Well thanks again will have a look. What about that underseal job? Stinks a bit mind.missfixit70 wrote:Probably have to order it from your local Mazda dealer, part number is in the thread somewhere, or on lushprojects (just make sure you get the one that looks the same as there are 2 other options for the 2 petrol models too), have a good check of the rest & see if any are imminent, especially top hose under drivers seat & the one at the rear that goes over the starter.
Well spotted PoirotNorthern Bongolow wrote:I would try to get rid of the jubilee clips as well if you can,order the proper clips from mazda
just a fluke this is more the normNorthern Bongolow wrote:re bleeding at the bash.
thanks for the offer of your motor for the bleed,but if anything were to happen/go wrong,say the timing belt snap it could cause major problems.plus dont know if ian would appreciate the scantilly clad girls that i last saw you with,butlins wasnt it, appearing on his video.then again
regards ady.
