Coolant level at 6.5cm. Is this too high?
Tel
Post by Tel » Sat Apr 24, 2010 5:54 pm
Hello
We are now proud owners of a 2.0l bongo. Thanks for everyone for the help and advice gained from this forum.
I am in the process of sorting out the compulsary pictures.
I have checked the coolant level since I took delivery and it has stayed the same and I have now completed approx 2000km.
Out of curiosity I decided to use the lolly pop stick method and found that it measures 6.5cm.
I knew it was above the maximum level but thought nothing of it as it was delivered by a reputable dealer.
It has a coolant alarm fitted (single wire)
Do i need to worry about the level?
Terry
dandemann8
Re: Coolant level at 6.5cm. Is this too high?
Post by dandemann8 » Sat Apr 24, 2010 6:03 pm
Hi and welcome, purchased mine from JAL in sept 09 annd noticed mine was over the max level indicator but after further investigation was told this wasn't a problem. :D :D
P.s. Don't forget to post your piccie's of your nice Bongo on "SHOW US YOUR BONGO" post. :D
Bongo no more........... ;-(
Post by haydn callow » Sat Apr 24, 2010 6:38 pm
that is a bit over full........next time it is all cool.......use somthing to suck out a bit.(not your mouth) a "basting" tube/sucker will be o.k. (don't let the wife see you) it should be on the TOP FULL line when cold (2 cms) and when hot it will raise about 1 cm above. Then always check when cold and it should always be on the full line.
Tel
Post by Tel » Tue Apr 27, 2010 9:25 pm
Thank you Dandemann8 and Haydn for the quick response. =D>
I have syphoned off a bit of coolant as suggested.
Sorry for the delay in responding, I wanted to post some photo's at the same time, they are now on the "SHOW US YOUR BONGO" post. :D
All the best Terry
