Starter motor contacts
Just got new starter solenoid contacts but would appreciate some confirmation as to which way round they go. On my starter the elongated contact is on the battery lead side of the solenoid but the photos in the fitting instructions that came with the contacts set show the elongated contact on the side with the fixed lead into the starter motor. Which side is correct?
Never run out of road, traction and ideas at the same time.
Re: Starter motor contacts
Can't help personally except:Tessie wrote:Just got new starter solenoid contacts but would appreciate some confirmation as to which way round they go. On my starter the elongated contact is on the battery lead side of the solenoid but the photos in the fitting instructions that came with the contacts set show the elongated contact on the side with the fixed lead into the starter motor. Which side is correct?
- is there a factsheet in the members area?
- will it become obvious when you strip down the starter motor and look at how things are arranged?
- I seem to recall the replacement kit is not suitable for starter motors on the twin battery cold weather Bongos as they have a different more powerful starter motor
Basically put em in the same way they came out, you'll probably find they don't line up if you do it differently. I did mine about 18 months ago, but couldn't tell you which way around from memory.
- maxheadroom
I thought you would be along before too long Kirstymissfixit70 wrote:Basically put em in the same way they came out, you'll probably find they don't line up if you do it differently. I did mine about 18 months ago, but couldn't tell you which way around from memory.
Just for the record, the elongated contact is fitted to the battery lead side of the solenoid.......well it is on mine anyway
I had a look at the factsheet and video but they didn't help with which way round the contacts went.....now I know they didn't need to
Thanks to you all for your quick replies
No probs and glad you got it sorted. Sounds like bullet point 2 gave the answer (i.e. will it become obvious when you strip down the starter motor and look at how things are arranged)
See Mike, you knew what you was talking about....you just didn't realise you knew
Tessie wrote:See Mike, you knew what you was talking about....you just didn't realise you knew
