Big Draught in passenger foot well
Posted: Sat Mar 13, 2010 9:05 pm
by Mattsonics
Been meaning to get to the bottom of this one for a while.
Has it been covered before?
I have found the source - which I am sure others will know as an aperture with a grill (inch spacings) behind the glove box - only felt it with air blowing through so far- not looked yet. I managed to do this whilst we were driving over the top of the Pennines where the air is obviously pretty cold - so more of a problem than at street level.
Thoughts?
Should this vent exist?
Matt
Re: Big Draft in passenger foot well
Posted: Sat Mar 13, 2010 11:12 pm
Could be as simple as one of the control links has come off, they are fitted as shown in this thread
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=26835
Posted: Sat Mar 13, 2010 11:21 pm
by missfixit70
Mattsonics wrote:Been meaning to get to the bottom of this one for a while.
Thoughts?
Matt
Just like on the back of 61-B03 here -
It's part of the air intake, as Geoff says check all your controls & linkages are conected ok, if you put it to recirc see if it stops.
FAQ here that may help -
http://www.igmaynard.co.uk/bongo/forum/ ... 43&t=28727
Re: Big Draught in passenger foot well
Posted: Sun Mar 14, 2010 6:57 pm
by Mattsonics
thanks
you were obviously correct!
for some dumb reason i had believed that the fresh air / recirculate controlled air fed solely into the heater matrix, which it obviously doesn't!
so basically unless you want cold air in all the time - this stays shut!? i.e. this fresh air isn't warmed.
Matt
Posted: Sun Mar 14, 2010 8:13 pm
by missfixit70
Check your linkages & flaps are working ok, never been aware of draughts in the nether regions of my passengers
& i don't often use the recirc control.
Do your heaters heat up ok?
Posted: Mon Mar 15, 2010 7:22 pm
by Mattsonics
Heater seems absolutely fine?
The recirculate control, controls a flap which is visible through the grill which seems to just open up to the outside world. would you expect the grill to be feeding into something else?
Maybe I am missing a part?
It can be quite cold in t' north!
Matt
Posted: Mon Mar 15, 2010 7:26 pm
by missfixit70
No that is how it's supposed to be , have a look on that lushprojects link.
Posted: Mon Mar 15, 2010 8:56 pm
by Mattsonics
Thanks Kirsty - I had a look at Lush Projects - it is actually very helpful!
I couldn't see any parts missing.
I do tend to drive about on the fells a lot - that probably has as much to do with it!
Matt
