				Removing rear passenger side window.
				Posted: Wed Feb 24, 2010 3:36 pm
				by Tony C
    I have arranged to have a ding which is just under the rear passenger side window repaired, this will require removal of the glass.
Advice on method please.
				Re: Removing rear passenger side window.
				Posted: Wed Feb 24, 2010 3:42 pm
				by missfixit70
				2 person job, hold the window from the outside, a couple of those dent puller/glass pane holder suction jobs are ideal to stop it dropping, then from the inside unclip the plastic covers over the  fixings   & unscrew , you'll have to force the plastic trim out of the way a bit (may be an idea to warm it a bit with a hairdryer if it's cold & a bit brittle to stop it cracking?), especially on the rearmost fixing, then it just lifts off, simplez
				Posted: Wed Feb 24, 2010 3:44 pm
				by Tony C
				Posted: Wed Feb 24, 2010 5:20 pm
				by missfixit70
