Heater blowing cold
Posted: Thu Feb 18, 2010 9:37 am
by Sanlaw
Can anyone help. My heater is blowing cold air. Have bled the system and flushed for gunk etc. Temp gauge is running mid way but just getting cold air through the heater.
Thanks - Sandra - Hants
Re: Heater blowing cold
Posted: Thu Feb 18, 2010 10:22 am
by wonkanoby
you have not bleed it right/fully im afraid
or the heater matrix has become blocked
but more likley needs more bleeding
and running long enough to open the stat
Posted: Thu Feb 18, 2010 10:52 am
by lpgimports
Find the feed and return to the heater and see if these are warm to the touch, if so then make sure the actuating rods on the side of the heater from the drivers footwell are actually moving and opening the flap in the heater for hot air. If cold pipes then bleeding or flushing heater matrix needed, or possibly replace matrix if no success.
Paul
Posted: Thu Feb 18, 2010 1:14 pm
by missfixit70
FAQ here
http://www.igmaynard.co.uk/bongo/forum/ ... 43&t=28727 that should help locate the flap linkages, I'd check that first before panicking too much. It'll also show you where to find the pipes to the front heater so you can see if they're getting hot. There have been a few heater matrix blockages recently, don't drive it until it's sorted just in case it's a blockage, you can always bypass it by connecting the inlet & outlet hose together as a short term fix/check.
Posted: Thu Feb 18, 2010 2:09 pm
by Sanlaw
Thanks for all the replies. Will let you know how I get on.
Sandra
