looking for i-alert or TM-2 info !
Posted: Mon Feb 08, 2010 1:36 pm
by lidgett-land
Hi all just been reading the new fact sheet on low coolent & temperature alarms, wanted to know more about the so called i-alert did the usual google search and didn't turn up any info so looked on ebay and still nothing, same with the TM-2 thats mentioned in the sheet, any one any more info ?
Re: looking for i-alert or TM-2 info !
Posted: Mon Feb 08, 2010 1:40 pm
by missfixit70
There are links/website addresses on the factsheet aren't there? just click on them, everthing apart from the Mason Alarm comes from the same place - Haydn Callow.
Posted: Mon Feb 08, 2010 3:39 pm
by haydn callow
P.M. Sent !!
Posted: Mon Feb 08, 2010 11:24 pm
by lidgett-land
Hi, there are no links on the fact sheet for the ones that haydn has on his website, maybe you should add a link, he has sent me the website link and I have been on, I shall be in touch when i decide what I want, I like the idea of the TM-2 LCA combo but not sure about the flashing red display as mentioned in the fact sheet, how often will it flash ?
I like the i-alert will it fit in a switch blank in a bongo ? and a seperate low coolent alarm I know its a more expensive combo but still trying to decide.
Posted: Tue Feb 09, 2010 9:43 am
by haydn callow
Only a couple of folks have commented on the flashing display. Thats 2 out of about 150....It blinks every couple of seconds as it updates.
Posted: Wed Feb 10, 2010 1:27 am
by lidgett-land
Hi hydn, I will get round to giving you a call when work lets up, but at the moment I am thinking about getting a "cube 1" and a LCA or 1 or maybe 2 i-alert's and a LCA (in green to match bongo dash)
I can see the size of the cube 1 from your website but could you give me the dimensions of the i-alert so I can see if they will fit in the switch blanks, also which one of the 2 devices is more acurate would you say, i know the i-alert reads up to 99 and then code but what about the cube what will that read up to ?
Regards Richard
Posted: Wed Feb 10, 2010 9:08 am
by haydn callow
The (( i-alert )) will fit in a switch blank.
I think the cube goes up to 130C
The Cube is the better built product
Both have the same accuracy.....
