				Shifter cable adjustment.
				Posted: Mon Feb 01, 2010 2:50 pm
				by thedogsbollox
				Just had my gearbox replaced for a second hand one and right away I noticed I cannot start up in Park. It will start in Neutral though. The roof still works whilst in Park, which I think is necessary for it to work right? A couple of times the reverse beeper has come on when putting into Park. I figure the shifter cable needs adjusting. Does it need yo go longer or shorter? Which end is the adjuster?
Tony
				Re: Shifter cable adjustment.
				Posted: Mon Feb 01, 2010 2:52 pm
				by missfixit70
				Doesn't have to be in park to put the roof up, just the handbrake has to be on. Not sure about any shifter adjustment though.
				Posted: Mon Feb 01, 2010 2:55 pm
				by missfixit70
				Not sure that this helps much -
http://www.lushprojects.com/bongopartsm ... mgno=.html - can't see anything immediately obvious as an adjustment.
				Posted: Mon Feb 01, 2010 5:18 pm
				by waycar8
				Tony if you take off the centre console, theres a clip on the handbrake it looks like you can move that by adjusting the screw and moving the bracket type thing thats attached to the cable towards the front it looks like thats the adjuster.
once you take off the center console stick your head down by the footwell and you will see under the cowling at the front of the handbrake, mines set in the middle but depending on the state of your cable it might be stretched and need pushing further up or down
				Posted: Mon Feb 01, 2010 5:20 pm
				by missfixit70
				waycar8 wrote:Tony if you take off the centre console, theres a clip on the handbrake it looks like you can move that by adjusting the screw and moving the bracket type thing thats attached to the cable towards the front it looks like thats the adjuster.
This sounds like handbrake adjustment Wayne? He wanted shifter adjustment
				Posted: Mon Feb 01, 2010 5:40 pm
				by waycar8
				ah just been out and checked, if the fates fatest cable on the front is for the handbrake then yes it is
But right next to it closest towards drivers seat, attached to the thin cable  is a thread bar that when twisted shortens so if you remove the small plastic cover by the drivers left knee if your sat in the bongo, Ive tried to turn it but it springs back, so you have to take the pin out ( number 46 525 on the lush projects drawing), then twist the bar and put it back together, I am presuming this is the adjuster
				Posted: Mon Feb 01, 2010 5:43 pm
				by missfixit70
				That looks like it could be it as it sounds like it's the interlock that needs adjusting rather than the actual shifter cable.
				Posted: Mon Feb 01, 2010 7:04 pm
				by thedogsbollox
				missfixit70 wrote:That looks like it could be it as it sounds like it's the interlock that needs adjusting rather than the actual shifter cable.
Oh, right the interlock, i never thought of that, of course it could be that. What is it????????????
				Posted: Mon Feb 01, 2010 7:27 pm
				by missfixit70
				Basically it's the cable (46-300 on the diagram thar goes up to the left) what's connected between the shifter & ignition that prevents it from starting unless it's in P or N
				Posted: Mon Feb 01, 2010 8:35 pm
				by thedogsbollox
				Good call. What about the reverse beeper coming on whilst in park(only happened twice and wasn't actually in reverse gear, this just needed selecting N then P again to cure it)
TDB
				Posted: Mon Feb 01, 2010 8:37 pm
				by thedogsbollox
				Aha. Just remembered that I also had a couple of problems removing the key! Tis all pointing to the interlock cable innit
				Posted: Sun Oct 01, 2023 12:03 pm
				by Tymmuffphii
				My gear shifter won't lock in Park, and for some reason I don't need to use the break peddle either.......
Same interlock cable?????
I have located this twist bar and removed the black plastic cover and adjusted it, but it hasn't actually done anything beneficial for my gear stick problems
				Posted: Sun Oct 01, 2023 12:53 pm
				The locking in Park is handled by the Large silver button and the ratchet mechanism inside in conjunction with the interlock cable for the foot brake.
				Posted: Sat Mar 30, 2024 8:13 pm
				by Tymmuffphii
				g8dhe wrote: Sun Oct 01, 2023 12:53 pm
Ok thanks for the advice but I honestly have no idea where to begin. I can't even remember now how it got like this lol. Also how do I tighten my hand real under the van. I looked today and followed the cable back and it's attached to a lever on the side of what looks like a tank or some sort with a long rubber gator on with a cotton pin on the end. It feels quite slack when hand break is on and off.
				Posted: Sat Mar 30, 2024 9:04 pm
				Maybe you need to refer to the mech. diagrams available here
https://www.lushprojects.com/bongopartsmk2/ follow the menu's down to locate the relevant diagram, it will at least show you what is what.  For more detail then its best to obtain from the Shop service manual(s) for which ever engine you have.
