Water alarm or voltage problem?
Posted: Sun Jan 24, 2010 6:34 pm
Hi, Help please
I have one of Haydn's excellent water alarms and for nearly two years now I have had to disconnect it when driving due to a very annoying gradual whining turning into full alarm over time (perhaps 5 mins). It works fine when first connected/engine first started but gradually starts to whine as explained above, so is fine for an instant test but not to leave connected. I believe I have narrowed the problem down to some kind of voltage or charging problem.
Obviously I would like it to be connected 24/7 but due to the whine it's not possible.
So my question is to all those 12v electric experts out there, how do I diagnose the problem?
Here are some points,
- I have a leisure battery fitted with one of the willinton kits
- the alarm neg wire (from the screw) is directly connected to the main battery negative and the other negative from the unit is to a good earth on the dash.
- the alarm pos wire (from the screw) runs through the body and into the unit as it comes fitted.
- the positive from the main unit is connected to the main battery via a spare fuse (courtesy of the willinton kit)
- I have tried connecting the positive directly to the main battery to ensure a good connection/circuit.
- adding to the electrical load when the alarm starts whining only increases the pitch of the alarm and brightness of the bulb until eventually it gets to full alarm and brightness
- the water level is fine and there are no leaks
- when the alarm starts to whine or is in full flow, shorting the two screws (in the expansion tank) stops the noise and when 'unshorted' the noise starts again gradually as above
- I have recently replaced the thermostat and used 50/50 coolant to water so the 'strength' is correct
- the output of the alternator is 'good'
- the leisure battery charges OK and has a 'good' voltage
- the main battery is only 12v when according to my cheap battery meter should be 12.4v to be 'good'
- the main battery is at least 2 years old but more than likely older as it is covered in Jap writing and no English and we are the second owners.
So am I missing something obvious? Should I replace the battery? is there a way to test the water alarm , although it has already saved me when a pipe leaked and worked correctly then!
over to the experts.......
oh and ps rather than ask Haydn directly I thought I'd offer it up here for a discussion and to possibly benifit others with the same issue in the future.
