V6 Petrol Fault Code Reference Source
Posted: Fri Jan 15, 2010 3:24 pm
Hi guys,
Found a website that firstly tells you how to get the error code out of the ECU by bridging the relevant pins on the diagnostics port.
If you then go to the next page you can put that code in, hit a button and it will tell you what it means.
Could be useful if the time comes:
http://codes.rennacs.com/plugins/MazdaS ... 96-929.php
