thermostat - 2 litre
Posted: Fri Dec 11, 2009 7:55 pm
by lee-jon
:? is the stat for 2l the same as v6? is there 1 from another mazda that fits?
Re: thermostat
Posted: Fri Dec 11, 2009 8:59 pm
by rita
lee-jon wrote::? is the stat for 2l the same as v6? is there 1 from another mazda that fits?
Was the stat missing or stuck open.
Re: thermostat
Posted: Sat Dec 12, 2009 1:27 am
by The Great Pretender
Why are you asking?
Re: thermostat
Posted: Sun Dec 13, 2009 11:50 am
by lee-jon
Why are you asking?
cos i want to replace, dont want to pull it apart without having new 1 to put in.
so is it the same or not???
Re: thermostat - 2 litre
Posted: Sun Dec 13, 2009 11:55 am
by Ian
As far as we can tell the 2.0 litre thermostat is unique to the Bongo. We have some on order from Japan and these will be available via the Bongo Shop in January.
Re: thermostat
Posted: Sun Dec 13, 2009 12:05 pm
by rita
Why are you asking?
Not
Posted: Mon Dec 14, 2009 10:11 pm
by apole
No the 2.0 thermostat is not the same at all.
I bought one for my V6 and although it looked the same, they had supplied the wrong one.
If you get one, and double check that you need one beforehand, get one from the Bongoshop, firstly because they will supply the right one, plus in my case it was a genuine one (the pattern one I bought first was very light by comparison) and then the price and delivery time is very good.
Not worth having the hassle of a full coolant change and bleed to find out the thermostat is wrong !! I learned the hard way on that one.
Hope this helps.
Andy
Posted: Mon Dec 14, 2009 10:27 pm
by lee-jon
thanks andy, a decent reply at last.thanks :P
Posted: Tue Dec 15, 2009 1:44 pm
by olebrock
I use BongoShop for all my 2.0l spares, you can be sure your getting the right part. One good thing on the 2.0 is that bleeding is a lot easier to do than the oil-burners (or dare I say it - the V6'ers). The bleed pipe is connected from the thermostat housing directly to the top of the expansion tank, making coolant change easy........ I still use the oil-burners method of engine revs/time but you don't need to hold up any hot bleed pipes.
