IVA test requiring sealing rear windows shut?
Posted: Thu Dec 10, 2009 11:46 pm
by Fraser
Has anyone else bought an IVA'd Bongo and found the rear windows have been sealed shut? I am being told by the dealer I bought it from that this was done in order for it to comply with the IVA test but he is saying its at my risk if I try to restore the windows to their original opening state and isnt being very forthcoming about exactly what he did to the windows to seal them (it looks like maybe a metal pin pushed into the window arm).
Anyone else had experience of this and more importanly any tips for how to make the windows open again ?!
Out of curiosity I have looked through the IVA testing manual to see why on earth it would be necessary to seal the windows but can't really find anything that gives me any clues. I can only assume it must be a security thing as the Bongo doesnt have an alarm?
Fraser
Re: IVA test requiring sealing rear windows shut?
Posted: Thu Dec 10, 2009 11:50 pm
by missfixit70
Not heard of that, do you mean the passenger side rear one? That never did open as it'd foul on the sliding door, the other 3 should open though :?
Posted: Thu Dec 10, 2009 11:56 pm
by madmile
Basically for the old SVA test, the windows were not allowed to open past the bodywork (to be honest its only a few mm on a bongo, but you have to have jobs for jobsworth :roll: ). People used to put a small self tapping screw through the plastic to prevent opening thereby creating a non opening window (no problem). IVA requires that the vehicle be more 'factory prepared' so a self tapper is not going to pass. As far as I understand, for a bongo to pass IVA the 3 opening windows need to be replaced with 3 non opening catches like on the rear n/s window.
If this is the case, then I am suprised that the dealer left them on as personally I would keep one set and swap them over after the stupid test.
I may have a set spare if you need them as I do have a full spare set of factory black glass and most of the catches. PM me if you get stuck.
Posted: Fri Dec 11, 2009 12:01 am
Well thats a 1st on BF - what a barmy bit of bureaucracy. :lol:
Posted: Fri Dec 11, 2009 12:04 am
by mister munkey
That'll be why mine had phillips screws it the window catches when I 1st got it. :!:
Never understood why they where there in the first place.
Another mystery solved.
8)
Posted: Fri Dec 11, 2009 12:21 am
by Fraser
Thanks madmile for your offer. As one of the three window catches appears to have been broken during the sealing process I am hoping the dealer will provide me with at least one replacement catch and that I can work out a way of un-sealing the other two myself. If I dont get anywhere I will be in touch.
