v6:smell of exhaust fumes/petrol
Posted: Fri Dec 04, 2009 9:53 pm
by hogggman
hi,
i have noticed this for a while,but it seems worse when stopped at traffic lights etc:
i get a distinct smell of exhaust fumes,occasionally a petrol-like smell,but this seems worse when either stopped at traffic lights,or when using the aircon or heating.it definitely seems worse when on hot,rather than cold,and it can be quite a strong smell.
i`ve checked the exhaust and it seems perfectly sound.i tried holding m palm over the exhaust pipe to listen for leaks,but there was too much pressure to even keep my hand there.
any other v6 owners noticed anything similar?perhaps the aircon needs a clean out?
thankyou
jamie
Re: v6:smell of exhaust fumes/petrol
Posted: Fri Dec 04, 2009 10:09 pm
by wishmaster
Hi hogggy, we have a smell, i would say like burnt oil, have had it since we bought our bongo, i find its worse when stationery at traffic lights, its got better with time but can still smell it when hot
Ive checked underneath but all's well, thought it might have been the underseal we had done at preparation
i think it maybe a little oil dripping onto the exhaust but cant see any evidence
Got ourselves a strong air freshener which does help
Your not on your own here mate
Regards Iz
Posted: Fri Dec 04, 2009 10:27 pm
Anyone for a scavenger over-ride switch? I don't talk about it much but apart from cooling the engine compartment so it didn't over-warm the car interior on a hot day, the other reason was to remove the occasional whiff of diesel I get in the cab, and which SWMBO wouldn't appreciate smelling. I flick it on discreetly it the first whiff - most effective I must say. Out of smell is out of mind
Posted: Fri Dec 04, 2009 11:03 pm
by munroman
Hi, could it be the Lambda sensor which should measure the air/fuel ratio and feedback to the ECU?
They do fail, which means the fuel ratio can be badly out.
Just an idea!
Posted: Fri Dec 04, 2009 11:16 pm
I think you might find quite a few V6's produce this sort of smell. Any oil that gets out of the engine, runs backwards down the engine block (the engine slopes backwards) and ends up dripping on the hot exhaust. As soon as you stop moving the smell rises up into the ventilation and into the Cab. We get this but it depends on the wind and how long the Bongo has been standing for before use. Once we've been travelling a while then the smell goes and doesn't come back till its been stationery for several days.
Posted: Sat Dec 05, 2009 3:03 am
by cheffy34
wishmaster wrote:Hi hogggy, we have a smell, i would say like burnt oil, have had it since we bought our bongo, i find its worse when stationery at traffic lights, its got better with time but can still smell it when hot
Regards Iz
You may find it's collecting in the lip of the sump and dripping onto the flexi pipe
seems to be my rocker cover seal
a few other possible nasties await closer inspection
but it looks pretty clean around the rest of it so
I only wish i had pockets as big as my petrol tank
or maybe smaller right boot
Posted: Sat Dec 05, 2009 3:20 am
by cheffy34
hogggman wrote:hi,
thankyou
jamie
Iv'e had it
but not since i had the well hidden crack in the pipe welded when it failed the mot
played havock with the emissions aswell
Posted: Sat Dec 05, 2009 9:32 am
g8dhe wrote:I think you might find quite a few V6's produce this sort of smell. Any oil that gets out of the engine, runs backwards down the engine block (the engine slopes backwards) and ends up dripping on the hot exhaust. As soon as you stop moving the smell rises up into the ventilation and into the Cab. We get this but it depends on the wind and how long the Bongo has been standing for before use. Once we've been travelling a while then the smell goes and doesn't come back till its been stationery for several days.
Indeed
Anyone for a scavenger fan over-ride (see above and
http://www.igmaynard.co.uk/bongo/forum/ ... =scavenger
Posted: Sat Dec 05, 2009 12:32 pm
by apole
I had this for ages, turns out it's the camshaft oil seals, drips down the front of the engine, round the lip of the sump onto the exhaust.
I'll let you know the cost next week but I've decided to get it fixed as I really hate the smell.
Andy
