Rear lights and dash lights not coming on!
Posted: Mon Nov 09, 2009 8:29 pm
by Bryno
Hello!
My rear lights and dash lights are not coming on, I have replaced the fuse(8) under the hood as suggested but they are still not working. please help?
Thank you for all you feedback from my previous emails.
Cheers, Bryn
Re: Rear lights and dash lights not coming on!
Posted: Mon Nov 09, 2009 8:50 pm
by missfixit70
As mentioned previously on one of the other threads it could be the relay which should be on the nearside (passenger)wing under the bonnet along with the headlight relay under a black rubber boot. It'll be behind the second battery or leisure battery if you've got either fitted, you'll have to remove the battery to get to it. they are interchangeable so you can swap to see if that's the issue.
This thread may help - http://www.igmaynard.co.uk/bongo/forum/ ... 05#p336605
Posted: Mon Nov 09, 2009 10:32 pm
by Bryno
Thank you so much! I did as you suggested and it is as you say. thank you for your help. you're a legend! :D
Cheers, Bryn
Posted: Mon Nov 09, 2009 10:41 pm
by daveblueozzie
Bryno wrote:Thank you so much! I did as you suggested and it is as you say. thank you for your help. you're a legend! :D
Cheers, Bryn
ive always said Kirsty was leg end. :lol: :wink:
Posted: Mon Nov 09, 2009 10:52 pm
by missfixit70
Cheers, Bryn
It's not the leg end that's the issue, it's the middle bendy bits that hurt :( :wink:
Posted: Tue Nov 10, 2009 1:03 am
by brorabongo
missfixit70 wrote:it's the middle bendy bits that hurt
I though it was only men that had those bits? :-#
[-o< they get better soon. Does this colder weather make things worse?
Posted: Tue Nov 10, 2009 1:05 am
by missfixit70
I just knew someone'd sink to the gutter :P :lol:
Posted: Tue Nov 10, 2009 1:26 am
by brorabongo
missfixit70 wrote:I just knew someone'd sink to the gutter :P :lol:
Thanks, I do my best. :lol:
As for the relay, make sure it was'nt due to water ingress, possibly due to a blocked drain hole below the windscreen.
